NEW - Draco AW80 - Finless ROM 1.1 - BETA2
Display Resolution Change With Peripherals...
I noticed that when I added an SATA drive (power off) that when I booted up I was no longer at 4k resolution. Resolution was changed without notification, just booted up with lower resolution. If kept everything the same (plugged in) there are no changes with repeated boot.
Also noticed that on boot up audio is always muted but no problem for me.
When trying to change wallpaper in 4k resolution mode it won't ever show apply button. Also, shows cropped image, so large size wallpaper is not possible (not even the default wallpaper size which is larger, looks like maybe 960 pixels wide?)
When I used ROM Toolbox Pro application I was able to change SD cache for internal disk. Much faster boot time and better performance when cache increased to 3072m. Also, with ROM Toolbox I was able to turn off Finless animation and that made it boot faster. Although confusing, I set animation to NONE and still there was an "android" animation?
This is probably not accepted practice, but I copied the Framework-res.apk to my Windows64 PC, renamed it to Framework-res.zip and opened the res folder and dragged a replacement pointer_arrow.png into the zip to replace the file that was there. I then copied the Framework-res.apk to the Tronsmart Draco AW80 and using MKC file application copied the new Framework-res.apk and replaced the existing Framework-res.apk This does cause it to freeze. But when I unplug and re-plug in, the cursor is changed (one pixel 80% transparent dot) barely visible.
It seems if you change more than the one png file it won't work. So, I'm out of a jam for tomorrow anyway. Hopefully, Finless Bob will figure out some more of the memory issues to optimize the 4GB of RAM better and maybe look into the SD cache optimization.
This box looks extremely promising, and I have been able to easily load Basic4Android applications onto it and run them with amazing performance comparable to a much more expensive laptop or desktop computer at 4k video resolution. AMAZING!!!!! I'm blown away, this is way more than a TV box.
I could be wrong, but I believe this rom to have this setting on 1920.
vs.
Code:ro.property.max_video_height=[B]2160[/B]
build prop of A80-4.4-6335-20141218_USB1.img:
Code:# begin build properties # autogenerated by buildinfo.sh ro.build.id=KOT49H ro.build.display.id=CS-Q8-eng 4.4.2 KOT49H 20141218 test-keys ro.build.version.incremental=20141127 ro.build.version.sdk=19 ro.build.version.codename=REL ro.build.version.release=4.4.2 ro.build.date.utc=1417074736 ro.build.type=eng ro.build.user=yuandan ro.build.host=sunchip-PowerEdge-R710 ro.build.tags=test-keys ro.product.model=CS-Q8 ro.product.brand=CS-Q8 ro.product.name=jaws_tvd_p3 ro.product.device=jaws-tvd-p3 ro.product.board=exdroid ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.manufacturer=Allwinner ro.product.locale.language=zh ro.product.locale.region=CN ro.wifi.channels= ro.board.platform=jaws # ro.build.product is obsolete; use ro.product.device ro.build.product=jaws-tvd-p3 # Do not try to parse ro.build.description or .fingerprint ro.build.description=CS-Q8-eng 4.4.2 KOT49H 20141127 test-keys ro.build.fingerprint=CS-Q8/jaws_tvd_p3/jaws-tvd-p3:4.4.2/KOT49H/20141127:eng/test-keys ro.build.characteristics=homlet # end build properties # # ADDITIONAL_BUILD_PROPERTIES # ro.com.android.dateformat=MM-dd-yyyy ro.config.ringtone=Ring_Synth_04.ogg ro.config.notification_sound=pixiedust.ogg ro.config.alarm_alert=Alarm_Classic.ogg drm.service.enabled=true wifi.interface=wlan0 wifi.supplicant_scan_interval=15 keyguard.no_require_sim=true ro.sys.network_location=true af.resampler.quality=4 audio.output.active=AUDIO_CODEC,AUDIO_HDMI audio.input.active=AUDIO_CODEC ro.sf.showhdmisettings=7 dev.disp_type=4 dev.disp_mode=10 ro.kernel.android.checkjni=0 ro.sw.testapkpackage=com.softwinner.dragonbox ro.sw.testapkclass=com.softwinner.dragonbox.Main ro.sw.testapkconfigclass=com.softwinner.dragonbox.Configuration ro.sw.agingtestpackage=com.softwinner.agingdragonbox ro.sw.agingtestclass=com.softwinner.agingdragonbox.Main ro.sw.snwritepackage=com.allwinnertech.dragonsn ro.sw.snwriteclass=com.allwinnertech.dragonsn.DragonSNActivity ro.opengles.version=196608 persist.sys.strictmode.visual=0 persist.sys.strictmode.disable=1 debug.hwc.showfps=0 persist.sf.showhdmisettings=7 persist.sys.hdmimode=10 persist.sys.hwc_p2p=0 persist.sys.disp_density=160 ro.sys.adaptive_memory=0 dalvik.vm.heapsize=512m dalvik.vm.heapstartsize=16m dalvik.vm.heapgrowthlimit=384m dalvik.vm.heaptargetutilization=0.75 dalvik.vm.heapminfree=2m dalvik.vm.heapmaxfree=8m ro.zygote.disable_gl_preload=true persist.sys.usb.config=mtp,adb ro.udisk.lable=CS-Q8 ro.adb.secure=0 ro.property.tabletUI=false ro.font.scale=1.30 ro.sf.hwrotation=0 debug.hwui.render_dirty_regions=false ro.property.max_video_height=2160 ro.setupwizard.mode=DISABLED ro.sys.cputype=UltraOcta-A80 persist.evb_flag=1 ro.hwui.texture_cache_size=170 ro.hwui.layer_cache_size=135 ro.hwui.path_cache_size=34 ro.hwui.shap_cache_size=9 ro.hwui.drop_shadow_cache_size=17 ro.hwui.r_buffer_cache_size=17 ro.sys.hiritsu=25 ro.product.firmware=CS-Q8_4.4.2-a80-v2.0rc3 ro.product.rom.type=YB ro.product.rom.name=BoxRom ro.softmouse.left.code=93 ro.softmouse.right.code=92 ro.softmouse.top.code=6 ro.softmouse.bottom.code=31 ro.softmouse.leftbtn.code=30 ro.softmouse.midbtn.code=-1 ro.softmouse.rightbtn.code=-1 ro.sw.shortpressleadshut=true ro.sw.directlypoweroff=true ro.carrier=wifi-only persist.sys.redKey=com.softwinner.TvdFileManager persist.sys.redKeyClass=com.softwinner.TvdFileManager.MainUI persist.sys.blueKey=com.android.settings persist.sys.blueKeyClass=com.android.settings.Settings persist.sys.yellowKey=com.android.browser persist.sys.yellowKeyClass=com.android.browser.BrowserActivity persist.sys.greenKey=com.togic.livevideo persist.sys.greenKeyClass=com.togic.launcher.MainActivity persist.sys.timezone=Asia/Shanghai persist.sys.country=US persist.sys.language=en persist.sys.device_name=CS-Q8 ro.com.google.gmsversion=4.4 persist.sys.dalvik.vm.lib=libdvm.so dalvik.vm.dexopt-flags=m=y net.bt.name=Android dalvik.vm.stack-trace-file=/data/anr/traces.txt # begin fota properties ro.fota.platform=AW_A80_KK ro.fota.type=box ro.fota.oem=sunchipA80_KK ro.fota.device=CS-Q8 ro.fota.version=CS-Q8-eng 4.4.2 KOT49H 20141127 test-keys # end fota properties
Thanks Finless!
Originally posted by Finless View PostOK folks.... This ROM is based off the Fantasy ROM since many liked it. But I did a lot to it this time and have learned a lot!
Enjoy,
Version 1.1 b2 is not perfect but does things the stock ROM doesn't. Some day I hope to learn to modify ROMs and tweak things and take these new amazing pieces of hardware to new heights of capability and use. There are a lot of headaches, but rewarding when it works! I'm still holding on with my fingernails but learning new Android stuff every day.
Installing Finless with SD Card Method
Originally posted by Finless View PostWatch box temps please. Let me know. If they remain cool I can bump the DDR speed to max from 480 to 672 (which is allowed) which surely will do even better!
I think I found a way with TWRP to flash just the config.sys part so I may be able to offer tweaks to those that want it and can go back easily without erasing and reflashing. That's my desire anyway.
More to do but glad it's working out!
I'm installing your ROM to my TELOS today using the SD Card method. When I insert the card into the Telos and power it up, how long should I let it run before unplugging the power and connecting it back up to TV? You say eight minutes, but is that safe or should I wait a 1/2 hour? Thanks!
[MBR]Burn Success
[]Burn Success
Error
Can you help please?
Thanks!
Originally posted by 140hours View PostBob, Something's going wrong when I try to write the Finless ROM to SD card using PT 3.09:
[MBR]Burn Success
[]Burn Success
Error
Thanks!
Originally posted by AlmontGreen View PostI'd start by formating the SD card first, if that doesn't work, try another SD card. If that doesn't work, try a different SD card reader/writer. I used 4GB SDHC card with no problem with cheap PRETEC P240 USB 3.0 card reader. I have heard of others having problems with different SD cards/readers... That might be a place to start troubleshooting anyway.
Format how, the PT 3.09 formats the card before it writes to it I thought?
I just took out 64GB UHC micro SD card from my Note 3 phone and am going to try again.
Originally posted by fredphoesh View PostI cant remember either Bob, but I am not convinced that the Hardware Keyboard Toggle in settings not sticking is the issue at all. I can have that setting on or off sometimes and I will not get the keyboard working again, no matter what settings I choose. At that point I have to reboot the Draco to get keyboard back.
BTW when I say keyboard, I mean keyboard, NOT the touchpad mouse... the touchpad mouse on the same keyboard ALWAYS works fine.
Happy 2015 to you!
I would like to flash back to stock... this keyboard breakdown issue is a major pain...
Could one of you post a link to the stock rom?
Thanks,
Mark._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
There are currently 2559 users online. 1 members and 2558 guests.
