Having a bit of an issue. I KNOW you have the answer
You have the box set at native resolution of 1080p.
However, for the aplication I am using, I need the native resolution set to 720p - and REMAIN there.
Apparently, when we change the resolution in display settings, if the box loses power, it reverts back to 1080p - the monitor I have it set up with is not 1080p (I am using this little devil as a server)
Is there a build.prop setting to make the native/default/fallback resoltuon at the 720p ?
I've looked at it...and just a little timid to make any changes
