NEW - Draco AW80 - Finless ROM 1.1 - BETA2
Originally posted by fredphoesh View PostWell, I can't find that thread, searching for power button or standby... Possibly due to the new Tapatalk being so horrible, only has global searches it seems.
Edit: I found "power button issues" (odd name since it has nothing to do with the power button itself) but no relevant solution to be found there.
If you know of another thread, please link to it for me... Tx Mark.
1) flash Finless rom with sd card method, not by usb.
2) don't install any app for 1 day.
3) put your box to sleep and wake it up after 15 minutes ,repeat it several times . Normally if the standby death is still there, you would get it. I got mine after just 1 minute .
4) the day after, repeat the same test, if that works , then install your apps
5) if after having installed your apps the problem comes back, then one of your apps is the cause.
Hello Everyone,
Last week I've flashed FINLESS ROM 1.1 on my Draco Telos. I found one small issue with sound. After Draco reboot sound setting changes automatically: HDMI output unchecked. After that I need to check that output setting again to have sound on my TV.
Another settings which disappears are keyboard related settings - input type. I'm using MELE F10 PRO keyboard so I'm choosing hardware input type, after reboot that setting disappear too.
I think the Mele F10 PRO is your 'friend' who forces to change the audio-settings...
=> https://play.google.com/store/apps/d...honeroutingfix
BTW: Keymap
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by frhdt007 View PostI have Meta, I have my way to create your problem and to fix it. Try this:
I guess I'll use Google Remote on my phone when the USB keyboard fails.
Tx for the input though._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Originally posted by fredphoesh View PostLordy! I may try that sometime... But it sounds like a hell of a process... And how do you find THE app? I'm guessing lollipop may come sooner :-\
This process is simply a process of elimination!
Originally posted by frhdt007 View PostJust try step 1, you'll know if it's hardware or software problem .
This process is simply a process of elimination!_________________________________________
Originally posted by fredphoesh View PostWell, yes and no... To Test app by app over a period of two days each would take way longer than any home theatre experience is worth... And then there is no guarantee that it is just one app doing it, may be a combination of apps, a conflict, or not an app at all bit some system error which shows up after time or when other criteria are met. This doesn't seem scientific or accurate at all, more like a superstition! Sorry to seem ungrateful but it doesn't strike me as a solution, but rather as wishful thinking. What app did YOU find was problematic, surely it would be the same dor others?
Isn't it scientific ? Sorry, but it is. It's the way every IT support debug a problem. Is unplugging the power cord every day a solution ? Not for me.
Originally posted by frhdt007 View PostYou seem to be the only one who accepts standby death !
If there actually is anyone who has done this process and found some app to be causing Standby death, then please share which app is causing this, it may save someone hundreds of hours of their life!_________________________________________
Originally posted by fredphoesh View PostI've had 4 android boxes, and none have had this problem. It is the drako boxes fault. I'd far rather pull out the plug every day and use my Google tv remote app when my keyboard fails than do a two day test for each app. That would take way too much time.
Originally posted by frhdt007 View PostYou're a kind of fast reader ! I never suggest 2 days test for each app. I just wrote big lines what to do, use your own judgment ._________________________________________
I can't get live streaming to work. I don't know why but streaming start and just stop after few seconds. It's not working even via broadcasters app, just start and stop after few seconds. Stream supplier is using adobe hds broadcast method. Streaming was working fine with my earlier MK802IV (android 4.4.2). I have tried almost every available firmware for draco but with same results. Any suggestions to solve this kind of problem?
Netflix and all "static" streams are working well but live stream isn't.
edit: Interesting. I changed to static ip and stream is not getting stuck but i lost picture, only sound is coming through. With dhcp mode i get picture and sound but only for few seconds and then stream run to endless buffering.Last edited by eich; 01-15-2015, 14:42.
Originally posted by fredphoesh View PostIt seems nobody has had success doing this, or did they not share which apps are to blame? Which caused problems for you?Last edited by frhdt007; 01-15-2015, 14:19.
Originally posted by eich View PostI can't get live streaming to work. I don't know why but streaming start and just stop after few seconds. It's not working even via broadcasters app, just start and stop after few seconds. Stream supplier is using adobe hds broadcast method. Streaming was working fine with my earlier MK802IV (android 4.4.2). I have tried almost every available firmware for draco but with same results. Any suggestions to solve this kind of problem?
Originally posted by frhdt007 View PostI have the same problem when streaming from Yandex.com with Chrome. With Dolphin and flash player, that works fine. Try that.
There are currently 2667 users online. 3 members and 2664 guests.
