Merry Xmas all
NEW - Draco AW80 - Finless ROM 1.1 - BETA2
OK I will do it. Maybe today but probably tomorrow.
Originally posted by Finless View PostI can tweak my 1.0 ROM with the video buffer and DDR speeds if you all would like to try that?
It would be nice to have easy way to get rid of bottom nav panel buttons permanently. And can I pay you to make a customization(s)?
Originally posted by AlmontGreen View PostIt would be nice to have easy way to get rid of bottom nav panel buttons permanently.
Add this one line (without the quotes) anywhere towards the end: "qemu.hw.mainkeys=1".
Reboot, and the buttons are gone.
Originally posted by Zahir View PostIf there isn't even a blue pinprick when you plug in power, seems like your box was faulty. Hope you can get a replacement asap.
@Bob, small bug?: some settings don't survive a reboot, like hardware keyboard under Language and Input. But the external keyboard still works...
Used MKC file utility to overwright Framework-res.apk (which works great with Minix Neo X8). Now trying with PhoenixCard again and nothing. Just blue light for a while and after several minutes it goes out.
2 bricked units in two days. Ouch!
Originally posted by Zahir View PostEdit the build.prop file in your "System" folder.
Worked great! Thanks. Not so much luck editing Framework-res.apk to change mouse cursor (pointer_arrow.png) and would like to have simple "starting..." screen on boot but no luck there yet.
Originally posted by AlmontGreen View PostWorked great! Thanks. Not so much luck editing Framework-res.apk to change mouse cursor (pointer_arrow.png) and would like to have simple "starting..." screen on boot but no luck there yet.
ps. but do not try install suggested rom's. since they are for real Samsung tablet.
Originally posted by AlmontGreen View PostI experimented with one unit and it stopped working after trying to connect OTG to PC. ...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by otisrhw View Post1. I noticed with power cord and OTG a buzzing sound so I unplugged power.
2. Also strange no blue light with usb but when power plugged in blue light and then when power unplugged and usb still plugged in blue light stayed on.
2. I don't know if you talk about powerd USB at the other side (e.g. PC or active HUB) but it's normal... also only after first regular powered on (I think because this device don't know a on/off hw switch)RK3288 Devices
Originally posted by no_spam_for_me View PostI also tried to use the USB30/OTG port at the back-side and connected it with an USB2.0 port at my NB, but get no problems after that, so what had you done?
This is MUCH easier since I could never get the USB driver signing issues resolved. Now if I can learn how to pack and unpack to make minor tweaks like mouse cursor and default_wallpaper that would be great. Those are mods to the framework-res.apk but I haven't learned how to replace that .apk without causing problems.
UltraHD playback using Basic4Android program I wrote.
I am seeing beautiful 4k video from Seiki 39" 4k TV from Tronsmart Draco AW80 with Finless rom 1.1b2 Playback is beautiful very smooth full screen and no bar at bottom with tweak to build.prop
My app is for digital signage. Only problem is loading/unloading of videos repeatedly seems to cause memory problem and app quits after about 50 or so different videos. This is why I got 4GB RAM version in hope that the app wouldn't run out of memory playing 4k video and showing 4000 pixel images. Actually, the images don't cause the app to quit, just loading/unloading different videos.
The Minix Neo X8 does not play 4k video so well and the memory problems were very bad for my app. It works great with HD resolution but not 4k (some weird artifacts in video that look like video driver problem).
Hope to learn how to unpack, make minor tweaks and repack or replace files without problems. Learning very much here from genius people like Bob!
There are currently 2882 users online. 4 members and 2878 guests.
