MK808B-Plus - Finless ROM 1.0
    Originally posted by sf! View Post
    It's write in capitals :
    FIRST REMOVE factory_update_parap.aml
    Not need format... the flash work, but stop at the verification...
    If you get
    Cause : "E : failed to verify whole-file signature"
    I don't think it flashes because verifying is something which normally happens before flashing...
    But you are right, the recovery seems to begin to read which file ever and try to verify the signature of it...
    RK3288 Devices
    - Overview BOX (LINK !)
      Clarification
      Originally posted by noderat View Post
      Use the stock recovery.img on sdcard instead of twrp.
      @noderat - could you please clarify this? I'm also trying to return to stock after flashing Finless 1.0 and I get the same error as @raks67
      Should I try the 107k4 recovery.img?
      Thanks in advance.
        Thanks in advance.
        Nevermind - figured it out. To anyone else looking to return to stock, what worked for me using the sdcard method was
        recovery.img from the 107k4 update
        factory_update_param.aml from the 109k4 update
        m201-ota-20141222.zip from the 109k4 update
          I have installed sopcast, but the screen remains black!! Why?? Help me please
            Anyone have any luck with CEC? It seems the hardware supports it, but I don't think the kernel module is acting correctly.
            Also, I don't seem to be able to attach my powered external hard drive. (It has a built in usb hub which may be the problem).
              I have only tested with unpowered flash drives which do work correctly. I'll test with a powered drive tonight.
              Only after you've donated to Finless and Neomode are you allowed to donate here.
                CEC works for me only for the first couple of keypresses and then stops. I think it is a kernel bug and there is no solution yet.
                  Is the updated version of MK808?
                  WOW. It looks so nice.
                  Thank you very much.
                    As with usual, great work finless, i have got this to replace my mk808b
                    any chance we can get a xpad.ko for 360 controllers to work?
                    thanks so much.
                    karl
                      Hello,
                      I'm just installing finless 1.0 on my mk808b-plus.
                      I can contribute my experience with some flashing problem:
                      I tried to install 109k4 stock rom but it doesn't work. The booting process when I tried to flash was : google tv logo, black screen, google tv logo and UI of 107k4. I tried with finless and the symptom was similar. I succeed in accessing in the twrp and remark that my micro SD (4GB) wasn't mounting. I changed it (8GB). Now, I can flash the finless rom 1.0 but not the stock rom.
                      Here is my new problem :
                      I don't have sound on all app (even XBMC). Could you help me ? Is there a fix ?
                      [edit] the problem comes from my HDMI câble ;-)
                      Thank you for your help.
                      PS: sorry for my poor english. It's not my mother tongue!
                        change to 720p and make density possible...
                        I have finless on my MK...
                        Now I need 720p. How can i change to this?
                        And I need another Density...
                        In Build.prob
                        #ro.sf.lcd_density
                        changed to
                        ro.sf.lcd_density 360
                        after restart nothing happens...
                        How can i change this, too??
                        Thx a lot....
                          Power form TV usb
                          Can MK808B Plus be powered from TV usb?
                            It can but it may keep crashing as the tv usb port is only 500MA & the stick rely needs 2000MA to run well
                              For me works super on usb my tv, just you need no connect usb hdd, i play all my video from nas.
                                Same here. Using USB to power mk808b and my media library is mounted with nfs
                                sent from my Nexus 4
                                Plasma: Panasonic TX-55ST60E
                                HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
                                powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
