NEW - 2dark4u ug802 ROM - fixes sync issues?
Originally posted by plushsat View PostAny quik n dirty way to make the right-click on an airmouse function as a back button again??
Go to this post on XDA and download the knrtracker and the buttom remapper.
http://forum.xda-developers.com/showthread.php?t=850464
See if you can use the tracker to find what key number is the air mouse back button. Then you might tray the remapper APP to change its function.
But once we know the number we can implement in the ROM.
Originally posted by Finless View PostI think I can fix this but we need to know WHAT the key number is for the air mouse back button.
Left Click = 272
Right Click = 273
Originally posted by plushsat View PostClockworkMod KeyTest shows:
Left Click = 272
Right Click = 273
Which click should be the APP back?
The mouse function is unusable in CWM as it's waaaay to touchy (as you had mentioned)
With the mouse 'off' before CWM is up, the keyboard and directional pad allows for navigating the menus.
Right-click always resulted in 'app back', the actual 'back' button works as a 'Delete' function
After a quick test, I can confirm that sync problems are almost gone... VERY GOOD, thank You!
I had some "strange" reboot of the UG802 and also some crash of applications that with Bob's 1.4a were working perfectly. But it was only after the first reboot after the update. After rebooting a couple of times it never happened again.
I' have also the "ESC" problem on a BT Logitech diNovo Mini keyboard that was working without problem in Bob's 1.4a. As soon as possible I will post the key number as suggested from Finless, even if I suspect that could be the same of AirMouse.
Next step for me is now flash in the hard way. Just 2 noob questions about:
- also with this rom if I flash the hard way I'll have 1 Gb for applications instead of 500 Mb?
- if I flash the hard way this time, next time I'll maintain the 1 Gb space also if I flash the easy way? Or I have to flash again in the hard way always?
Thank you very much Finless and 2dark4u for your hard work!
I checked his ROM and YES.... if you flash the hard way you will get the 1GB APP space.
About my ESC button not working with a BT Logitech diNovo mini Keyboard:
For example I can't go back from playng a video inside the ehomeMediacenter. On your 1.4a was working in hat way.
The ESC key of my keyboard read inside knrtracker is nr. 1
I hope to have correctly understood what I should have done to help....
There are currently 1512 users online. 1 members and 1511 guests.
