+1 ... same sync problam for me
NEW - 2dark4u ug802 ROM - fixes sync issues?
Originally posted by sunday View Post+1 ... same sync problam for me
This ROM is definitely way ahead of the original one in the device, I love the included launcher, the wifi is great, but the audio and video are still slightly out of sync making it not usable as a media center - my key intention when getting the device.
Hope you guys keep on the great work and get this devices working beautifully with your signatures on it!
Originally posted by 2dark4u View Post
_______________________
Edited by Finless:
Here is the FreakTab direct download link for 2dark4u ROM.
ROM -> ug802 2dark4u ROM based on Finless 1.4a - PC flash tool version (170 megs)
ROM -> ug802 2dark4u ROM based on Finless 1.4a - Easy update version (170 megs)
Logout. Then from the top of the web site login and clikc the box keep me logged in.
Issues with Play Store
Hi, and thanks for all the work you guys (finless and 2dark4u) do to get the ug802 to work as intended!
However I have after installing the new ROM (the hard way) i had some problem with play store..
Whatever i try to download i got an error message (dont recall the exact but something about the server wasnt available,) but after few reboots it seems to be working.
About the wifi (an anoying thing) the icon shows constantly 50% doesnt matter how close i bring it to the router or if I select another connection (tried with my neighbours) it constantly shows 50% even if the bar is 1 it shows 50% and never goes above..
thanks for now and keep up the good work guys!
Originally posted by miiku View PostHi, and thanks for all the work you guys (finless and 2dark4u) do to get the ug802 to work as intended!
This is not the WiFi sinal! Just the ~battery~ wich does not existis.
Regards!
It wont as the easy way will not repartition NAND.
bug reporting
Thanks for the great rom. Now HW acceleration is working and youtube is in sync.
I'm using mVideoPLayer - only with it, HW accel. is working, and also in stock player that comes with UG802.
Subtitles are played also fine. Used CIFS manager to mount my NAS shared folders. mVideoPlayer opens them fine, video played good streaming through Wifi together with subtitles.
I have an issue with my Logitech K400. I'm using "null keyboard", in order to hide soft keyboard when typing, but now only touch pad of my K400 is working, not the keyboard. It worked with previous finless ROM. Any ideas ?
There are currently 2619 users online. 0 members and 2619 guests.
