NEW - Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.1 ROM
Hello,
hope you can help me to get external player working in Kodi.
I use Andoer S82B with this Finless Rom. Kodi 15.0 Beta 2.
I followed the How-To on kodi.wiki: http://kodi.wiki/view/HOW-TO:Use_ext...ers_on_Android
These are the versions of MXPlayerFree and ArchosVideo. Video is not playing. MXPlayer says:"This Video can not be played.". ArchosVideo says:
"File corrupted or incomplete." In the settings of MXPlayer i activated the hardware decoder.
Editing part of playercorefactory.xml for MXPlayerFree:
********** EDIT THIS SECTION **********
<rule protocols="smb" player="MXPlayerFree" />
<rule dvdimage="true" player="MXPlayerFree"/>
<rule protocols="rtmp" player="MXPlayerFree"/>
<rule protocols="rtsp" player="MXPlayerFree" />
<rule protocols="sop" player="MXPlayerFree" />
<rule internetstream="true" player="MXPlayerFree" />
<rule video="true" player="MXPlayerFree"/> <!-- Default for anything else not listed -->
</rules>
</playercorefactory>
Editing part of playercorefactory.xml for ArchosVideo:
<rule protocols="smb" player="ArchosVideo" />
<rule dvdimage="true" player="ArchosVideo"/>
<rule protocols="rtmp" player="ArchosVideo"/>
<rule protocols="rtsp" player="ArchosVideo" />
<rule protocols="sop" player="ArchosVideo" />
<rule internetstream="true" player="ArchosVideo" />
<rule video="true" player="ArchosVideo"/> <!-- Default for anything else not listed -->
</rules>
Thank you for your time and help.
</rules>
</rules>
It would also be useful to find, and install Adaway as well. if your going to use the free version. As it kills the in-app-advertising, in essence giving you the full version.
Thanks. I found my mistake. Had spaces before and after MXPlayerFree in the xml. Cause of using copy and paste while editing with es explorer on the s82. Now MXPlayerFree works. But i cant choose settings on the player. There is no settings like on the installation on the smartphone. Guess i need to choose harware decoder in the settings, right? For now i cant change this.
I tried Archos Player as well but it dont start. It says: External player active. Press ok if playing ends.
I dont have a solution for this. Archos was my first choice as an external player.
Reason to change to external player are the small lags of the internal player. Maybe the lags will still be there with external player. I have to try.
Guys, can you help.
My M8 runs this ROM better than anything. BUT....I don't have Bluetooth using v2.1. I have Bluetooth running just fine in v1.7 and v1.8 Finless ROMS, but not this one.
I've tried different methods of install and upgrade too.
Is it because this ROM is not designed specificlly for my device? I have an M8 (OTT).
The older Finless ROMS did not work with CPU Temp app and seemed to only show battery temps, which is useless in a media player, so this is why ideally I would love to get Bluetooth working in this ROM on my device so that I can get Sixaxis set up again for my emulators.
Any advice and time is greatly appreciated.
T
I own a MXIII (1gb version) that I bought off Amazon from Pigfly Tech. Is your rom compatible with my device?
Manufacturer - MBX
Model - MXIII_1G (k200)
CPU - ARMv7
Chipset - Amlogic Meson8
Current Android VVersion - 4.4.2
Kernel - 3.10.33
S802
Let me know if I left out any helpful info. Thanks!Last edited by joeshmoe666; 26 July 2015, 23:59.
Originally posted by Finless View PostLink fixed..... My bad
I've got a question. I've connected my devide by ethernet. But my speed doesn't get higher then 32 Mbps. When i connect it by Wifi i've got a speed of 55 Mbps. Why is my connection so slow. Please help. How can i get it get fixed. greetings.Last edited by djdave79; 27 August 2015, 17:41.
If i remember correctly the firmware got a bug in it concerning the Ethernet.
I believe this was tweaked to fix the issues http://freaktab.com/forum/tv-player-...om-remix-115k4Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostIf i remember correctly the firmware got a bug in it concerning the Ethernet.
There are currently 2353 users online. 0 members and 2353 guests.
