NEW - Beelink S82/S82H/M8/MXIII & Tronsmart S89/S89H - Finless 2.1 ROM
Hello
I recently purchased what appears to be a MXIII 2GB version firmware is m111k4. i have been trying to install this rom, but i could not get to recovery. It just gets stuck at the SMART TV screen ( the screen that comes up right after you press power ). I of course have held down the recovery button at the back inside the audio port, but it will not go to recovery however long i hold it down. i eventually turn off the device, then boot it back up normally, which it does, and i can normally use it. I have also attempted flasing this ROM via the update app, but when it restarts, it gets stuck again at the boot logo.
It seems I cant get to the recovery mode whicever option I use in the read me file of Finless. Please help. And thank you in advance.
Originally posted by DexDrive View PostHello
I recently purchased what appears to be a MXIII 2GB version ...snip....
- power plug out of the machine - power plug back into the machine.
- hold the recovery button (and keep holding)
- hold the power button (and keep holding, whilst you already are also holding the recovery button)
- hold both for about 10 seconds
- still machine was "frozen" on the first picture
- let go of recovery + power
...and then just wait and do NOT turn off the machine..
It took minutes, I had actually been cursing, gone to the toilet, washed my hands, been to the kitchen, cursed some more, grabbed my laptop to search this forum for a solution.. and suddenly out of nowhere, it started to boot TWRP.
No idea why on earth it took forever to get there.. but once TWRP came up, I got super excited - slammed in the files on a USB stick, and installed from TWRP.
Now.. this led to another couple of hours or cursing.. because no matter what image I tried to install,
each boot (normal or recovery) would come back to TWRP.. with two errors, one being "unable to find partition size for '/bootloader'"
(grabbed it from my search history, i think the other was /bootenv, but i'm not sure)
So.. I read and re-read Finless' instructions only to realise 4-5 hours later... OH SHIT.. it's the first line:
1) Copy all the files from this ZIP onto the SDcard
So.. SDcard Tim.. not a USB stick (sigh)... even after installing Android roms some 50+ times on 20+ different devices I made a stupid mistake
So, I popped in the files on a TF card, fed the MKIII the card hopefull and reset the machine with the recovery button as described above.
This time it only took seconds, and started the android update screen.
On reboot.. it did not work.. super surprised.. it show the android update screen again.. and whilst a bit of more cursing was involved,
for good luck.. i thought I might try patienceIt seems like it went through the exact same install as before.. but this time it worked
Hope that helps.
Tim
*edit* - ps -> if you can boot your device in stock rom, why not install TWRP from android store, and from there let it force a reboot to TWRP in booting? might need root installed, but if I remember correctly I used that on a tablet recently
Hello Tim007, thank you for your suggestion. i did the exact steps you outlined, even fell asleep leaving the box and my TV on ( i did it around 12 midnight ) and woke up 2 hours later, and the screen was still stuck at that first screen, no recovery mode. Restarted the box, did it again, fell asleep again and woke up after 2 hours and still no go. Is it possible that i have a MXIII that does not actually have recov mode? Or is it disabled somewhere?
Originally posted by tim007 View PostHey Bob..i've trotted through all 26 pages of this thread, but noone asked the most important question..
Where did your DONATE button go?
I'd like to send you a few bucks as a thank you for this excellent rom
Bob's donate button is still there, its in his signature, at the bottom of all his posts.ThanksPlease consider making a Donation to freakTab
Originally posted by blinkone View Post
Hi there,
Strange enough, I noticed checking your message earlier on my phone, it also contains a signature.. checking on my pc running windows explorer 11, no signature for you.. ok strange.. so I went to Bob's first post.. and voila.. nothing.. checking on my phone, I don't see a donate option.. but suddenly I do see his "Forgive theam as they know not what they do" message in multiple languages..
going to dive into my user settings here, as I don't understand why i'm not seeing signatures
*edit* yes! found it.. Conversation Detail Options -> Visible Post Elements -> Show Signatures
Sent Bob a litte appreciation
Hello guys,
I'm newby in the forum, after start using MXIII 2gb.
Received it last week. Setup, kodi and the stuff. And overall it's good. The only thing is that WIFI reception is awful. My wifi network ensures ~40 Mbps (Laptop, smartphone, confirmed via speedtest), but MXIII receives only about 1 - 3 Mbps. Tried many android tweaks and factory reset, but no succes. I'm desperate. I can't use it, like this.
Searched in the internet and ended up here. I will appreciate some help.
- Is my MXIII Finless rom compatible?
- Will it improve wifi reception?
- Is there another method to improve the wifi?
I have purchased the device by Gearbest and it's specs says that it's Netxeon.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi, guys!! Please, anyone of you who have flashed this rom could just try for a moment the MET OPERA ONDEMAND app from playstore, to see if videos are properly played. Mine with stock firmware only plays sound, image is black. But other ondemand apps like youtube or Netflix work fine...the same app works in my 4.4.2 tablet
Originally posted by javiko_bcn View PostHi, can i flash this rom to an MXIII-G with amlogic s812? Can i brick it?
There are currently 2552 users online. 1 members and 2551 guests.
