iPhone6 using Tapatalk
Kodi 14 (Helix) with passthrough (libmedia hack)
Thank you so much JMCM. I am still having trouble to get get the sound from all the 5 channels. Only the speaker and Subwoofer. I am doing anything wrong?? After installation of Kodi, I rebooted/restarted my android box and run config wizard after the installation completed. Thanks for your help and quick response.
Originally posted by hamed20mThank you so much JMCM. I am still having trouble to get get the sound from all the 5 channels. Only the speaker and Subwoofer. I am doing anything wrong?? After installation of Kodi, I rebooted/restarted my android box and run config wizard after the installation completed. Thanks for your help and quick response.
Originally posted by hamed20mThanks for your quick response. I checked it in the android box setting and it is correct. My android box is Q7 model CS918 rk3188. I have not tried prior versions yet. My android box is not rooted. Should I root it to be able to use this? I really appreciate your help.
Originally posted by eullin View Posthi
The hack in Beelink I68 not working, i have re-flash the rom....
Solution?
Regards
It only works on KitKat firmware not Lollipop firmware that is on Beelink I68.
For Beelink I68 use Rockchip's Kodi in the latest RK3368 firmware or Wasser firmware with optimized Kodi specific for RK3368 devices.
Originally posted by jmcm View PostHi, here it is kodi 15.1 with the libmedia hack: https://mega.nz/#!WxwjAZBR!KtVSfWLCP...pLL6-v442mjDGcTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There are currently 1708 users online. 1 members and 1707 guests.
