Someone else could shine a light on this?
OSCAM SUPPORT / PICTURES
Originally posted by markfarner View PostThanks for your answer. I already tried that but I couldn't see the OSCam binary. It's also a bit cumbersome to have to unpack and pack the .apk, especially as lately there are some 10 updates each day. In a standard deco you can simply replace the binary.
Someone else could shine a light on this?«Сомалійська Наноелектроника та Космонавтика»- VS-IP015 - Android Sat Receiver - g18ref_th2
- WeTek Play - Android Sat Receiver - g18ref
Get my oscam package from experimental cm build and have a look how I start itWeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Originally posted by ChristianTroy View PostGet my oscam package from experimental cm build and have a look how I start it
My idea is to get rid of OSTool and just start manually with a script OSCam at android boot.
If you can unpack/pack Android boot images you can edit init.rc and add
Code:service oscam /system/bin/oscam -b -r2 -c /sdcard/oscam user root group root disabled oneshot on property:dev.bootcomplete=1 start oscam
WeTek Play
I update Ostool to oscam+emu r10932
Code:Unix starttime: 1438530396 Starttime: 02.08.2015 18:46:36 Version: oscam-1.20-unstable_svn-r10932 Compiler: arm-linux-androideabi-ssl Box type: generic (generic) TempDir: /tmp/.oscam ConfigDir: /sdcard/config/ WebifPort: 8888 Web interface support: yes LiveLog support: yes jQuery support intern: yes Touch interface support: yes SSL support: yes DVB API support: yes DVB API with AZBOX support: no DVB API with MCA support: no DVB API with COOLAPI support: no DVB API with STAPI support: no DVB API with STAPI5 support: no DVB API read-sdt charsets: yes Irdeto guessing: yes Anti-cascading support: yes Debug mode: yes Monitor: yes Loadbalancing support: yes Cache exchange support: yes CW Cycle Check support: yes LCD support: no LED support: no Emulator support: yes Clockfix with realtime clock: yes IPv6 support: no camd 3.3x: no camd 3.5 UDP: yes camd 3.5 TCP: yes newcamd: yes CCcam: yes CCcam share: yes gbox: yes radegast: yes scam: yes serial: yes constant CW: yes Pandora: yes ghttp: yes Reader support: yes Nagra: yes Irdeto: yes Conax: yes Cryptoworks: yes Seca: yes Viaccess: yes NDS Videoguard: yes DRE Crypt: yes TONGFANG: yes Bulcrypt: yes Griffin: yes DGCrypt: yes cardreader_phoenix: yes cardreader_internal_azbox: no cardreader_internal_coolapi: no cardreader_internal_sci: yes cardreader_sc8in1: yes cardreader_mp35: yes cardreader_smargo: yes cardreader_pcsc: no cardreader_smartreader: no cardreader_db2com: yes cardreader_stapi: no cardreader_stapi5: no cardreader_stinger: yes
Please I need A help To configure Newcamd As a Client On wetek play With Oscam Tool.
I Have Paid IKS (Internet Key Sharing) http://iksprivateserver.com/ To Watch Dish Network Usa (nagra 3)
And I Have Configured it On Dreambox Using Rqcamd Or Mgcamd And It Working Fine.
But On Wetek Play I Do Not Get It To Work
I Logged With Wetek Ip:8888 And I Made a reader Up And I Add Newcamd Protocol
And I Fill It As:
Device :31.220.2.30,12210
User:xxxxxxxxxxxx
Pass:xxxxxxxxxxxx
DesKey:6103403445406970987123412134
And I Thick Conect On Init
And It Do Not Work I reboot My Wetek And I restar Ostool Apk On The Receiver
The Live Log From The Status Section:
Scard/config/No Softcam.key Found
So Pleas I Need Someone Can Help Me
This The Log View- 2015/08/16 14:33:51 137F08 h >> OSCam << cardserver log switched, version 1.20-unstable_svn, build r10096 (arm-linux-androideabi)
- 2015/08/16 14:33:51 137F08 h Refresh Server requested by WebIF from 192.168.15.6
- 2015/08/16 14:34:31 0 --- Skipped 1 duplicated log lines ---
- 2015/08/16 14:34:31 137F08 h Reader Wetek_ restarted by WebIF from 192.168.15.6
- 2015/08/16 14:34:32 15B528 p Wetek_ [newcamd] creating thread for device 4.nfpsserver.tv
- 2015/08/16 14:34:32 15D360 p proxy 4.nfpsserver.tv:12210 newcamd525 (fd=0)
- 2015/08/16 14:34:32 15D360 p 4.nfpsserver.tv: resolved ip=31.220.2.30
- 2015/08/16 14:34:32 15D360 p Wetek_ [newcamd] connecting to 4.nfpsserver.tv:12210
- 2015/08/16 14:34:33 15D360 p login failed for user '************'
- 2015/08/16 14:34:33 15D360 p Wetek_ [newcamd] disconnected: reason login error1
- 2015/08/16 14:34:33 15D360 p Wetek_ [newcamd] proxy initialized, server 4.nfpsserver.tv:12210
in ostool works all protocol good !
in you log see bad login or passwod data.
Code:[LIST][*]2015/08/16 14:34:32 15D360 p Wetek_ [newcamd] connecting to 4.nfpsserver.tv:12210[*]2015/08/16 14:34:33 15D360 p[B] login failed for user[/B] '************'[*]2015/08/16 14:34:33 15D360 p Wetek_ [newcamd] disconnected: reason[B] login error1[/B][/LIST]
Still On Tv Scrambled Channel
I have just fill my server setting on newcamd only
on the Status i see anonymous and local_dvb with error
did i have to do some thing ales- 2015/08/16 17:39:43 132FEB0 p Reader-2 [newcamd] connecting to 31.220.2.30:12210
- 2015/08/16 17:39:44 132FEB0 p Newcamd Server: 31.220.2.30:12210 - UserID: 0
- 2015/08/16 17:39:44 132FEB0 p CAID: 1816 - UA: 0000000000000000 - Provider # 1
- 2015/08/16 17:39:44 132FEB0 p Provider ID: 000101 - SA: 00000000
- 2015/08/16 17:39:44 131A8F8 c anonymous (1816&000000/0000/027B/92:06E3AE0D75BC03A8A08CA4E70CD498CE): not found (1011 ms) by Reader-2
- 2015/08/16 17:39:44 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:44 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:44 131A8F8 c anonymous (1840&000000/0000/027B/A5:147A411600D9DD5A44B7B27321416611): not found (1 ms) by Reader-2
- 2015/08/16 17:39:45 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:45 131A8F8 c anonymous (1816&000000/0000/027B/92:06E3AE0D75BC03A8A08CA4E70CD498CE): not found (0 ms) by Reader-2
- 2015/08/16 17:39:45 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:46 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:46 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (1 ms) by Reader-2
- 2015/08/16 17:39:46 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:46 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (1 ms) by Reader-2
- 2015/08/16 17:39:47 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:47 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:47 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (1 ms) by Reader-2
- 2015/08/16 17:39:48 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:48 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (1 ms) by Reader-2
- 2015/08/16 17:39:48 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:49 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:49 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (28 ms) by Reader-2
- 2015/08/16 17:39:49 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:49 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (1 ms) by Reader-2
- 2015/08/16 17:39:50 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:50 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:50 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (5 ms) by Reader-2
- 2015/08/16 17:39:51 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:51 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (30 ms) by Reader-2
- 2015/08/16 17:39:51 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:52 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:52 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (1 ms) by Reader-2
- 2015/08/16 17:39:52 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:53 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (1 ms) by Reader-2
- 2015/08/16 17:39:53 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:53 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:53 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (1 ms) by Reader-2
- 2015/08/16 17:39:54 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:54 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (1 ms) by Reader-2
- 2015/08/16 17:39:54 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:55 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:55 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (4 ms) by Reader-2
- 2015/08/16 17:39:55 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:55 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (0 ms) by Reader-2
- 2015/08/16 17:39:56 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:56 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:56 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (1 ms) by Reader-2
- 2015/08/16 17:39:57 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:57 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (4 ms) by Reader-2
- 2015/08/16 17:39:57 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:57 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:58 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (1 ms) by Reader-2
- 2015/08/16 17:39:58 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:58 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (1 ms) by Reader-2
- 2015/08/16 17:39:59 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:39:59 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:39:59 131A8F8 c anonymous (1840&000000/0000/027B/A5:B2340F4F636F62E470A9A0E3733835DE): not found (1 ms) by Reader-2
- 2015/08/16 17:40:00 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:00 131A8F8 c anonymous (1816&000000/0000/027B/92:AA274CEE6DCB7D0F1BD4D037BF2A0452): not found (1 ms) by Reader-2
- 2015/08/16 17:40:00 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:00 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:01 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (1 ms) by Reader-2
- 2015/08/16 17:40:01 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:01 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (1 ms) by Reader-2
- 2015/08/16 17:40:02 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:02 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:02 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (1 ms) by Reader-2
- 2015/08/16 17:40:03 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:03 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (3 ms) by Reader-2
- 2015/08/16 17:40:03 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:03 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:04 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (48 ms) by Reader-2
- 2015/08/16 17:40:04 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:04 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (1 ms) by Reader-2
- 2015/08/16 17:40:05 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:05 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:05 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (1 ms) by Reader-2
- 2015/08/16 17:40:06 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:06 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (27 ms) by Reader-2
- 2015/08/16 17:40:06 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:07 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:07 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (1 ms) by Reader-2
- 2015/08/16 17:40:07 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:07 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (1 ms) by Reader-2
- 2015/08/16 17:40:08 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:08 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:08 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (0 ms) by Reader-2
- 2015/08/16 17:40:09 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:09 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (1 ms) by Reader-2
- 2015/08/16 17:40:09 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:10 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:10 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (1 ms) by Reader-2
- 2015/08/16 17:40:10 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:11 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (1 ms) by Reader-2
- 2015/08/16 17:40:11 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:11 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:11 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (1 ms) by Reader-2
- 2015/08/16 17:40:12 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:12 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (1 ms) by Reader-2
- 2015/08/16 17:40:12 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:13 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:13 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (1 ms) by Reader-2
- 2015/08/16 17:40:13 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:14 131A8F8 c anonymous (1816&000000/0000/027B/92:C077A29158810547CA91917B5259BDB3): not found (0 ms) by Reader-2
- 2015/08/16 17:40:14 131A8F8 c [DVBAPI] Demuxer #0 (re)starting decodingrequests on all 2 ecmpids!
- 2015/08/16 17:40:14 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #0 CAID 1840 PROVID 000000 ECMPID 012C ANY CHID PMTPID 0000 VPID 1022
- 2015/08/16 17:40:14 131A8F8 c anonymous (1840&000000/0000/027B/A5:BD635AC6D05B20F2E12B2060C7D63373): not found (0 ms) by Reader-2
- 2015/08/16 17:40:15 131A8F8 c [DVBAPI] Demuxer #0 trying to descramble PID #1 CAID 1816 PROVID 000000 ECMPID 002C ANY CHID PMTPID 0000 VPID 1022
There are currently 1272 users online. 0 members and 1272 guests.
