Hello Bob and forum friends, recently received a H8 Plus, the box has the factory firmware ending in 114 11/14/2014. My question is whether I should first install the stock firmware 002, or 1.0 before installing 1.1 Rom? thanks
Finless 1.1 ROM for the Minix X8H-PLUS
My new X8 Plus update???
Hello Bob and forum friends, recently received a H8 Plus, the box has the factory firmware ending in 114 11/14/2014. My question is whether I should first install the stock firmware 002, or 1.0 before installing 1.1 Rom? thanksLast edited by yaesu555; 04 January 2015, 16:04.
Originally posted by yaesu555 View PostHello Bob and forum friends, recently received a H8 Plus, the box has the factory firmware ending in 114 11/14/2014. My question is whether I should first install the stock firmware 002, or 1.0 before installing 1.1 Rom? thanks
Originally posted by amd64 View PostHi! Bob.
I update your new rom x8-h plus v1.1 finless rom.
However, how can I rollback minix stock rom?
minix stock rom is only one img file and burning tool. it's not zip file like as your finless rom.
Do I need to update stock recovery for stock rom img file?
Originally posted by Finless View PostYou can flash my ROM directly. No need to make steps.
Either flash the stock ROM using the burning tool or in a sticky here I also provided 002a as a flashable ZIP.
However, for flash minix strock rom img file by amlogic burning tool, Do I need rollback stock_recovery.zip in twrp?
I conected usb cable to otg. But, amlogic burning tool doesnt connect m x8-h plus.
my tv box go to twrp recovery menu.
Originally posted by amd64 View Postthanks Bob.
However, for flash minix strock rom img file, Do I need rollback stock_recovery.zip in twrp?
Originally posted by ginandtonic View PostThank you, Bob.
Very good work.
I am having problems with Xbmc, can't seem able to install video add-ons, 1-Channel. Navi-X, etc..
Add-on installation fails or download stops!
For anything XBMC or Kodi, you must go to the sources for troubles with that!
My ROM's are base products. But I try to make sure they work the BEST when it comes to XBMC/Kodi. But if you have some issue with those, pretty sure my ROM won't be the cause!
Originally posted by WeK05 View PostHaving the device listed in the Google supported devices list would be the official Google confirmation. Until Minix makes a public statement, there are a few other signs that can be checked: 1) A Top Paid Apps tab in Play Store 2) Download option for Google Play Movies 3) HD option in Google Play Movies etc. The screenshots below are from Nexus 7. I get the same options on my $13 Nobis tablet which is also Google certified.
I cannot see these options on the X8-H. May be some one can check it on the X8-H Plus. Is HDCP fully implemented on the latest X8-H firmware?
[ATTACH=CONFIG]9536[/ATTACH] [ATTACH=CONFIG]9537[/ATTACH]
Thanks.Minix X8-H Plus - Finless Bob ROM 1.1 / GB Tronsmart MK908ii - Finless Bob 2.0 Beta KK ROM, D33 v300 OC
Originally posted by Finless View PostMy ROM will have noting to do with those issues my friend.
Yes. you're right, it's the XBMC Youtube add-on which is messed up I think, or maybe something else..
It only seems to happen with the 002 firmware. i have downgraded to official firmware version 20141122 and the problem disappears..Last edited by ginandtonic; 05 January 2015, 15:39.
Originally posted by ginandtonic View PostYes. you're right, it's the XBMC Youtube add-on which is messed up I think, or maybe something else..
Hi Bob,
Thanks for the good work on this rom, I have just installed it but did not have the time to test it extensively though...
I tried your nexus spoof, but it seems the device keeps being detected as T-Mobile US model, so I can't install some french tv apps (it seems stock build.prop is also detected as t-mobile)...
I tried playing with the ro.carrier setting but 'unknown' or 'wifi-only' don't seem to change that (still t-mobile US), and I don't find any build.prop entry that seems to relate to carrier setting...
Do you know how to change that spoof ? Maybe it has to do with the ro.build settings (fingerprint?), but as I don't have access to a stock nexus build.prop I don't know what to set...
There are currently 1824 users online. 1 members and 1823 guests.
