Finless 1.1 ROM for the Minix X8H-PLUS
Originally posted by Deco View Post
Do you have to be unroot and have firmware installed before installing the firmware 003 or is it like a full build rather than an upgrade? Or rather should I say how much Finless Rom would we lose if one where to decide to revert back to firmware. I know there are some multi rom options out that could manage both the Rom's at the same time but who is putting out more updates or will there ever be a LTS version not sure if Chinese dev's even use software versioning names like LTS. Any Minix Chinese dev's out there that want to reply or do any of them ever browse here?
Originally posted by barrybsmith View PostDo you have to be unroot and have firmware installed before installing the firmware 003 or is it like a full build rather than an upgrade? Or rather should I say how much Finless Rom would we lose if one where to decide to revert back to firmware. I know there are some multi rom options out that could manage both the Rom's at the same time but who is putting out more updates or will there ever be a LTS version not sure if Chinese dev's even use software versioning names like LTS. Any Minix Chinese dev's out there that want to reply or do any of them ever browse here?
Originally posted by StanTek View PostUnrooting is unnecessary. All stock roms are unrooted. When you install a rom it wipes your drive clean and installs its on OS system on the drive. You don't want a dual OS system on these boxes. It's a waste of space. Listen, once you start using custom roms, you would want to stick with them because they are better than stock roms. However, once you find a custom rom that works for you, you don't have to update your rom every time a new one comes out, lol. A lot of us do it for testing and know how to restore back to their old rom if they don't like the new one.
Originally posted by Finless View PostPLEASE NOTE:
Minix has now been Google certified. What this means is special keys have been flashed to NAND.
The kernel checks these keys and if they are not right it wont boot.
Because of this, the stock recovery will ONLY boot from NAND memory.
It will not boot the stock recovery from SDcard!
If you are on a pre-11/22 ROM then to flash my ROM you need the recovery.img I provide in this ZIP on Sdcard.
The one in NAND memory pre-11/22 does not work (blank screen).
What I have done is put a non-locked kernel in this recovery and in the TWRP recovery I provide.
These work fine from SDcard or NAND.
I'm familiar with changing roms on my phone but the minix is somewhat different. Any information would be appreciated!
Originally posted by rpgmaker View PostI downloaded the rom and read the README. If I'm on a 11/22 stock rom do I still need to copy the recovery.img to SD card? I don't know if it doesn't hurt to have it there regardless of rom or if its just for pre-11/22 roms specifically.
Originally posted by ColinB63 View PostIt wont hurt, the after 11/22 just won't use it. Put it on there to be sure.
My first observation is that the rom boots really fast compared to the stock rom. Don't know if this comes from mainline 002 since I never did upgrade to that one but I doubt it.
I do have a question though (standard one I try to find out after messing with custom roms), how can I go back to stock minix? For example, if I wanted to install the stock 003 can I install it on my machine using the "USB burning tool" official method without issues? Since the recoveries are changed I'm not sure...
There are currently 2159 users online. 0 members and 2159 guests.
