Chuwi VX3 RileyROM 1.0
    By request, here's a RileyROM for the Chuwi VX3. So far it's untested...so it's a good idea to let someone with experience try this one out and report the findings. It's based on official Chuwi firmware.
    This ROM is:
    Rooted with CWM Superuser
    Debloated
    Init.d/Busybox support added
    Google Play Store fixes added
    English as default language
    Reboot App by Petrus
    I've added a CWM Recovery.img file I've made with MTK Droid Tools, but it's untested.
    If this ROM makes a difference for you, please consider a donation to support future RileyROM development.
    Enjoy!!!!!!!!!!
    Download v1.0
    Randy
    Whooo..it works
    Thanks rrileypm..
      Randy
        Some help
        Can i earn some help from you how to flash this ROM on my vx3?
          There is a First Time User's Guide PDF file inside the ROM zip.
          Randy
            So its flashing like else ROM, yes?
            This ROM is based on stock or update?
              how to...
              I'ts hard do do something in the recovery mode because all is in chinese !
              I can't reconize anything in these menu
              Can someone help ?
                English recovery is under power + vol. Up, this chiniese one is fabric mode.
                  thanks Pokawa !
                  working ! excellent... I always use POWER + VOL(-)
                  and the solution for english recovey is POWER + VOL(+)
                  big thx again
                    Halp
                    I read it carefully and i got trouble. PDA dont see chuwi while he is turned off, in device manager he is named My HTC and when i tried to manually update drivers it say's that drives are up to date. When i tried to flash (click download and then plug in USB 2.0) i got that sound but for some reason after it show's "power off charging mode" it's start to normal charging... and download doesn't start. Imma sad.
                      I got it!
                      Ok, i got it, i finally flashed this ROM on damn chuwi.
                      I saw that my system dont recognise driver for chuwi after i connect it in preloader mode.
                      Driver which helped me is MT6577 USB VCOM drivers, I installed it with help from this site.
                      Hope this will help someone
                        It actually helped!
                        thanks!
                          But im getting slow touch respond on landscape mode, and i have no recovery.
                          Any ideas?
                            Any ideas?
                            Nope :C
                              hi , i have a problem with the chuwi vx3 tablet ,
                              when i insert my sim it does recognise it but no network signal at all ,
                              it possible to be locked the tablet ? is something that i can do ? thanks .
