Chuwi VX3 RileyROM 1.0
Depending on the settings you used when flashing, you might have erased your IMEI code from your tablet. Check the threads in the MTK section for information of IMEI recovery. I'm mobile, so I can't provide a link right away.Randy
Thanks ,
after so many hours of searching softwares and solutions i decide to open the tablet to check hardware ,i am writing this post/ for someone thwt has the same problem ,
So Finally i found that the antenna doesnt fit to the mobo of the tablet so i fixed it and works great know.
I bought this tablet from alixpress, i sent it back to get fixed,,
They sent it to chuwi to fix it and after 4 months arrived back to me and as you understand i fixed it by my self.....
So beware where you buy from.
Sometimes it's the simple stuff that gets overlooked. I've heard of antenna problems before, but it's not the first thing I think of.
I'm glad you got it working!!!!!Randy
There are currently 1992 users online. 2 members and 1990 guests.
