What are the working models of WebCam(cam+mic)
UG802 Finless ROM 1.6 "custom" JellyBean - Made from MK802-3
Originally posted by 123421342 View PostHey Bob, I flashed your ROM and is great! Just so everyone knows' go launcher ex tablet version works great!
My TV's native res is 720p
Originally posted by bbjayo View PostI tried this with the 1.6 rom but found that the HD wallpapers didn't scale very well - they appear zoomed in with no way to adjust.
Originally posted by 123421342 View PostWhat do you mean zoomed in? Do you mean the video output was not scaled? If so, there is an option to adjust the scaling of the display.
there's an app for that!
Originally posted by bbjayo View PostProbably didn't explain it very well. Text / Icons appear o but the wallpaper looks as if it's being spread over 3 screens so that it's always blurred / zoomed in. I'll play around with it a bit more but I couldn't find any settings that would let me adjust it much
Standard Android feature.
Get a custom launcher on there, like Apex and turn off wall paper scrolling, then download "Image 2 Wallpaper".
Use that app to do what you want.
I dont know if it can be fixed in your rom, but sometimes the wifi will stop working and still show a good signal. I would have to disable and enable the connection. It happens randomly and I have two other computers that work fine while the ug802 is having the problem. Its completely random but it seems to happen most when I open the play store. Its not the biggest deal and Im going to test it more. Thanks for a great rom!
installing larger games?
Hi everyone!
Bob many thx for 1.6 - works great! I have a question about installing larger games on my UG802 - flash 1,6. I'm not able to install Need for speed Most wanted. It says: You don't have nought sorage, clear some spade on your memory or SD card (required is 1920 MB). Is there any solution to this problem? Is it possible to install on SD card (I have inserted 16GB card)?
Many thanks for all answers!
Matt
Matt
go to settings --> storage and check if SD card is mounted, if not mount it and try again
Starting in Android ICS they changed how external SDcard works. External is intended for media only. Internal SD is now considered the place where apps will go when you move them to SD.
It's a long story! But this can be tweaked. However if you tweak it in vold.fstab some apps may not work properly moved to sd and some apps then wont even see your internal sd which has much better performance than external.
There are currently 2108 users online. 4 members and 2104 guests.
