[Startup !]
instead of
[Product]
No? You should
[2015/1/6 7:53:39] Device OK, the size of the device is 30588 M. [2015/1/6 7:53:47] Formatting the card... [2015/1/6 7:53:58] Start Burning... [2015/1/6 7:53:59] [pheonix card_00]Burn Sucess [2015/1/6 7:54:0] [pheonix card_10]Burn Sucess [2015/1/6 7:54:0] [MBR]Burn Sucess [2015/1/6 7:54:4] [bootloader]Burn Sucess [2015/1/6 7:54:5] [env]Burn Sucess [2015/1/6 7:54:10] [boot]Burn Sucess [2015/1/6 7:55:26] [system]Burn Sucess [2015/1/6 7:55:34] [misc]Burn Sucess [2015/1/6 7:55:34] [recovery]Burn Sucess [2015/1/6 7:55:35] [sysrecovery]Burn Sucess [2015/1/6 7:55:40] [DATA File]Burn Sucess [2015/1/6 7:55:40] [pheonix card_00]Check Complete [2015/1/6 7:55:40] [pheonix card_10]Check Complete [2015/1/6 7:55:40] [MBR]Check Complete [2015/1/6 7:55:40] [bootloader]Check Complete [2015/1/6 7:55:40] [env]Check Complete [2015/1/6 7:55:40] [boot]Check Complete [2015/1/6 7:55:45] [system]Check Complete [2015/1/6 7:55:45] [misc]Check Complete [2015/1/6 7:55:45] [recovery]Check Complete [2015/1/6 7:55:45] [sysrecovery]Check Complete [2015/1/6 7:55:45] [DATA File]Check Complete [2015/1/6 7:55:46] Magic Complete [2015/1/6 7:55:46] Burn End...
Actually I'm at Finless 1.1 (based off Fantasy) from a 32GB SD Card
(actually flashed stock rom at a 16GB device)
Here you can find the
PhoenixCard 3.09 http://www.freaktab.com/showthread.p...e-Flash-Method
(3.1.0 http://dl.cubieboard.org/model/cc-a8...irmware-tools/)
Linux: NO WAY at the moment !!!
