Boot from SD
    Originally posted by no_spam_for_me View Post
    I see some characters at the filename I don't like... e.g. the blank between . and img?????
    But I'm actually downloading the Linux image and will try it....
    So I did and so I renamed the file name but got err again and again
    So I'll try to download Linux img again
    But what ever what happened it is a great way
    Now I can test any ROMs without losing my own using ROM
    and can even make a different SD Cards ROMs for a different ROMs
    Just hopping Linux will work to be perfect
    Thank you
      cs918s, have you try with sd or usb ( 16 Gb/ 32 Gb ) ?
        Sandisk class 10 SD Card 32 GB
          Some thing strange happened
          Previously I got 47094 with Finless 1.1 in normal way install ROM in antutu
          Now with SD Card ROM I got higher 49989
            Linux
            OK, no way with Linux (at the moment?)...
            With or without blanks at filename/path, with 3.09 or 3.10 and also after a reboot I got always the same Error:
            Maybe because of different partition-layout????
            Code:
            [2015/1/6 19:17:19] Device OK, the size of the device is 30588 M.
            [2015/1/6 19:17:29] Formatting the card...
            [2015/1/6 19:17:38] Start Burning...
            [2015/1/6 19:17:38] [pheonix card_00]Burn Sucess
            [2015/1/6 19:17:39] [pheonix card_10]Burn Sucess
            [2015/1/6 19:17:40] [MBR]Burn Sucess
            [2015/1/6 19:17:44] [bootloader]Burn Sucess
            [2015/1/6 19:17:44] [env]Burn Sucess
            [2015/1/6 19:17:47] [boot]Burn Sucess
            RK3288 Devices
            - Overview BOX (LINK !)
              Maybe the SD is faster then the eMMC/NAND...
              RK3288 Devices
                This is very exciting.
                Less of a need for TWRP now, since you really won't have to back up your current ROM to test a new ROM.
                I can't wait for a new ROM to test.
                Thanks for this info.
                  Here is alot and updated
                    [ATTACH=CONFIG]9651[/ATTACH]
                    Code:
                    100% Like me and at the same step
                      I've actually been messing around with this for over a week.
                      I managed to get ubuntu burned to an 8GB sd card.
                      First I was using the sdk and finally got it to build properly, and packed it into a livesuit image. I used phoenixcard to burn the sdk linux image in startup mode and it was successful!
                      I went further and unpacked the image from the sdk and the 20141230 ubuntu image. I figured out that by swapping the little rootfs.fex and rootfs.fex.iso from the sdk image to the 20141230 ubuntu image that it would burn. So I imagine it is a problem with partitioning and the size of the rootfs.
                      At the point the 8GB card I made would boot only to the splash screen and the kernel image.
                      I read through the .fex files with a hex editor and found that the rootfs.fex is written to the 7th partition, so I used dd to write rootfs.fex to /dev/sdb7. Now it boots from my sd card.
                      I made a dd backup of my 8GB card, so if anyone wants it I wrote up a quick post on armtvtech.
                      I've also been experimenting with other ways to boot from the sd card.
                      So far I've figured out where to write boot0_sdcard.fex and u-boot.fex, but I'm still working on where everything else goes, but it can at least boot to the first splash screen.
                        Hi. I'm a new member, and I've been reading the forums a lot lately. I haven't received my Draco AW80 from Geekbuying yet but that hasn't stopped my from trying to learn as much as I can before it arrives. I'm just wondering what are the downside to booting from the SD?
                        Thank You
                          Message Number 4 this thread last bit,
                          To date no downside at all.
                          Cheers
                            Loving it!😂
                              Cheers
                              Hey, thanks for the reply, I appreciate it. I read msg #4
                              "Arrr This has got my attention!! So are you saying that i could flash a rom to a sd card by selecting (Startup) instead of (Product) & once its inserted in to the draco it will boot from sd card :-) leaving the orignal system rom intact on the device..so if i was to eject the sd card it will then boot the orignal system rom..Or have i miss understood you."
                              I hope the one I have quoted was the one you were referring to, if not I'm sorry. But I was basically wondering if things like booting up, or read and write speeds would be slower due to the SD card?
                              Thanks Again
                                Should have mentioned #5 also
                                Yep answer is also here read number #21....
                                Also the type of card you use may have some effect message number #2
                                Its all new and just found recently (less than 24 hours) at the time of writing
                                Give it a week or so but it is looking good
                                Real good..
                                Cheers
                                Thanks Again
