Some of my friends and family saw it running and thought it was cool. They wanted one.
I purchased 3 more Tronsmart MK908ii devices. I decided to flash with Finless 1.6 just as I did with the original device. Everything went well during the flashing. I then attached the device to the TV and it started right away.
Unfortunately during the initial configuration when I tried to activate the Wi-Fi it searched for a connection, but within 2 seconds it switched back to “OFF” and displayed a “Wi-Fi is disabled” message.I tried this many times using 2 different devices without success.
I checked the 3rddevice without flashing to the Finless 1.6 ROM.It was able to connect to Wi-Fi. I re-flashed one of the failing devices to the original ROM and it worked in connecting to Wi-Fi!!!
I searched the forum, butcouldn’t anything to try and resolve my problem.The only difference I could find is that the new devices are 1.4 GHz.
Possible solutions and other information:
- Flash AP6210 by D33 as kernel (How to tell if I have a 6210 chip?)
- JB 4.2.2,RK3188t, Finless 1.6 w/720, 4GB parameter
Please don’t tell me I have to stick with the original Tronsmart ROM, I want Finless!!
Thanks,
Tazer98
