You can order direct or to contact factory rep thru meegopad store at Aliexpress here: http://www.aliexpress.com/store/1490893
MeeGoPad T01 Windows 8.1 TV Stick, first boot and streaming test, Kodi Helix build
I made a short video showing boot up and streaming video both thru youtube and Kodi media player:
You can order direct or to contact factory rep thru meegopad store at Aliexpress here: http://www.aliexpress.com/store/1490893Last edited by bloatman; 11 January 2015, 15:59.Tags: None
error booting
Hi guys,
I bought this stick and probably did something wrong. It doesnt startup and only gives an error that the installation was canceled. the advice is to rerun but that doesnt help.
Anyone any good ideas? it is pretty frustrating, especialy because i dont have a idea what tot do.
thanks forvany tips
thanks forvany tips
Originally posted by bloatman View Postok its 4.4gb, it will be ready in 30minutes, I have not tried it as I was trying to get the dual boot image which will be ready next week I'm told. I will post the link once it's ready.
For now thnx a bunch!!
I don't know where you had uploaded it, but I think you should use a split archive (also possible at ZIP) with e.g. 900MB parts... If your hoster also doesn't allow it, try e.g. http://www.file-upload.net/ but you should know at download the people have to useto avoid spam
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostI don't know where you had uploaded it, but I think you should use a split archive (also possible at ZIP) with e.g. 900MB parts... If your hoster also doesn't allow it, try e.g. http://www.file-upload.net/ but you should know at download the people have to use [ATTACH=CONFIG]9837[/ATTACH] to avoid spam...
Oh no, no torrents, please noRK3288 Devices
But then you are the hoster, or not?
If yes, have funRK3288 Devices
Originally posted by mikekremer View PostDoes anybody have a qworking winload.efi file to share??
15 GB storage free, limit 10 GB per file, file will be never deleted.
cheers
There are currently 2631 users online. 0 members and 2631 guests.
