Pipo M9 Max
    Pipo M9 Max
    I found a partial DMESG for an M9Max and also have some coaching from FreakTab developer DNKN.
    The hardware appears to be almost identical to an M6 Pro
    • lightsensor = us5151
    • mma8452
    • Accelerometer - lis3dh
    • Compass - akm8963
    • gyro - l3g4200d
    • touchscreen - VTL CT363
    • touchscreen - Goodix GT928
    • LCD - Hannix 1280x960 (ds1006h)
    • Bluetooth - mt6622
    • Codec - RT5631
    • front cam - ov5640
    • back cam - ov2659
      wifi - MT5931
    First test
    v1.00
    Donate to Finless
    this is a 4.4 or a 4.2 kernel?
      Pipo M9 Max
      4.4.2 kitkat
      Donate to Finless
        i just test it in Riley Rom 2.6.4. It doesn't boot. Just turn on backlight for 3 seconds and then turn off backlight for 3 seconds and so on.
          Thanks for the feedback. I'll upload a second test later this evening.
          Donate to Finless
            v1.01
            Donate to Finless
              Originally posted by d33 View Post
              When you push power, it turns backlight and led flash on. Then after ~5sec turns off led flash and after 30 seconds tablet shuts down completely.
                Here is a DMESG I created for a Pipo M9 Max which has 1 nand chip.
                dmesg-001.txt
                Hope this might be of help
                  @d33
                  can you pass on what you've learnt from dnkn? I know he had a custom kernel for M9 max, so there must be a working source/config somewhere.
                  I own M9 max so I can can build and test things, but I'm new here and so far I couldn't find a reliable starting point... I'm on stock 4.2.2 and for now I don't want to upgrade the rom, just need to tweak the kernel to make it usable...
                  Searching for rk3188 on github spits out a lot of mess, and most of the kernels I've found are for some tv sticks. Haven't found any pipo_defconfig anywhere...
                  I want to add some features to the kernel that I need:
                  - f2fs
                  - my cpufreq governor
                  - sysfs interface for oc/uv for anything that can be controlled
                  And of course some basic stuff to init.rc, like init.d/boot.d scripts handling.
                  Can you point me to where dnkn left it (I've seen his github, but that source has only initial commit, so I assume that his other work is somewhere else...)
                    I have a m9max with one nandchip too, if i can support this work with anything, write a pm to me.
                    Im using KitKat from dnkn.
                      Is there still any development going on for the pipo M9 max?
                      Maybe I am mistaken, but this thread did not seem to have brought any results yet, or did I misunderstand something?
                      It would be nice to see at least the buggy loader fixed, so that we can have full performance on the device.
                        I've come back to this one for another quick try if anyone is interested in testing
                        Donate to Finless
                          I now have acquired a faulty M9 Max to, hopefully, fix and use as a test bed.
                          Donate to Finless
                            Following
                              I just tried the latest Version on my single nand M9 Max running the 4.4.2 Rom from dnkn and i have the same problem as kandilak with version 1.0.
                              If you need some kind of log just tell me what kind and how i could pull it from the device and i will provide it
