CUBE TALK9X U65GT_V2.0.4B_Lepi_150115
    Hello and good morning!
    Thank you for developing this rom and for all the help you have ever dispensed!
    I just installed the rom and everything went well.
    As I now have a "yes" card for 3G data, the tablet displays the message: "Unfortunately the process com.android.phone stopped" and press ok, reappearsit impossible the use of the tablet.
    How can I solve this problem and keep the data card (I live in Portugal and the card is the operator "MEO")
      In the first post added
      Patch to replace the gray navigation bar at the black
      videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
      TWRP_2.8.1.0
      TWRP_2810_newTheme TWRP_2.8.5.0
      PayPal donate WMID410517421626
        Lepi - latest patch
        Thanks Lepi. BTW I am now used to the orange colour.
          Originally posted by lepi
          4. Implemented development niorix for instant flash drives mount the file system NTFS. Thanks to the author a remarkable development. But backup of the contents of both flash drives just in case make.
          Hi Lepi,
          thanks for including this nice feature (ntfs). I just upgraded on 2.04B and it seems to work pretty well with a 64gb sdxc card.
          Is there a chance to get exFat support for sdcard and usbotg also working ?
          Would be nice, to put sdxc from the camera in cube to show pictures. Actually I do not know an camera which supports ntfs :-(
            Good morning my friends!
            I've found the solution!
            Was here http://www.freaktab.com/showthread.p...l=1#post204444
            and results, fantastic!
              Is this what I think it is?
              Does this patch remove the orange color to stock UI colors?
              Lepi, this would be sooooo perfekt.
                TWRP ?
                I have a newbie question for the experts...
                How do I install TWRP on the Cube Talk 9x ?
                TIA for helping me...
                  simply use SP_flashtool and install TWRP recovery instead of stock recovery image.
                    ...before that you'll have to extract recovery.img from TWRP .zip archive.
                      ...of course! Thanks!
                      Last question : where can i find the scatter file?
                        of course, as written by Edius EVERY file flashed by SP_flashtool NEED to be .img files...
                          and what about the scatter.txt file ?
                            it's not a problem, use the one included as default in any custom rom!
                              Thanks master !!!!!!!!!!!!
                                You know there is another way that is pretty easy to flash a new recovery on your Cube. I use "Mobileuncle Tools. Just put the recovery.img on your sd card. Yes, the recovery has to be a .img. Open up Mobileuncle tools and go to "Recovery Update". It will take care of the rest. That's what I originally used and it work like a charm. Super quick, super easy. Any updates later I just use TWRP.
