CUBE TALK9X U65GT_V2.0.4B_Lepi_150115
Lepi, is there a way to add the NTFS fix on stock V.2.0 ROM? (for example installing a .zip file in TWRP recovery mode as for brightness patch)if you appreciate my efforts this is the link for any donation:
niorix's patch
Originally posted by giouncino View PostLepi, is there a way to add the NTFS fix on stock V.2.0 ROM? (for example installing a .zip file in TWRP recovery mode as for brightness patch)
thank you very much!if you appreciate my efforts this is the link for any donation:
ROM install
Hi.
I just took delivery of this tab and I noticed that after installing a few apps it started telling me memory to delete some apps. Please advice me, can i install this your ROM on it and will it fix the low memory problem? My serial number is B1503
Thank you Sir.
Originally posted by Lepi View PostOnly for tablets with a serial number higher than B1426XXXXXXX!
Serial number can find on the back cover at the bottom near the connector Micro USB.
Hi, my friends. I publish new mod-version U65GT_V2.0.4B_Lepi_150115.
Made on the basis of the previous modification U65GT_V2.0.3W_ru_Lepi_150111.
Additional changes to the version U65GT_V2.0.3W_ru_Lepi_150111.
1. Almost Stock black theme in orange supplement.
2. The default mode is Multi User 9 users. You can add the required amount of themselves without additional patches.
3. Modified Engineering menu. Now it does not hide the tab BandMode and other settings that were previously not available during multiyuzera. Thank you for helping Alexey arsenev modification.
4. Implemented development niorix for instant flash drives mount the file system NTFS. Thanks to the author a remarkable development. But backup of the contents of both flash drives just in case make.
Installation Instructions:
Only for installation through modrecovery CWM or TWRP!
Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card. Then make the necessary wipes tab ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
The first boot lasts a long time, you need to wait patiently and not to touch the display.If you put this firmware over the last firmware version 2.0.1Black, you can wipes are also not do.
There are no guarantees! Risk and assumes responsibility fully by the user.
Preliminary backup is required!
Successful upgrade!
ADD:
1. Patch for install orange Dialer.
2. Patch to replace the gray navigation bar at the black in the firmware U65GT_V2.0.4B_Lepi_150115.
Download
upd_U65GT_204B_SysUIblack.zip
Only for CWM or TWRP!
Successful upgrade!Last edited by fran6; 03 February 2015, 09:58.
ROM install
And how do I install Cwm/twarp? Somebody should pls help...
Thank you Sir.
Originally posted by fran6 View PostAnd how do I install Cwm/twarp? Somebody should pls help...
Enter in CWM and flash Lepi's TWRP.
Make all wipes described in Lepi's ROM first post.
ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Flash Lepi's ROM through TWRP.
ROM update
Thank you for your post sir. My tab came with a 2.0 software version, does it mean I can flash the 1.8 superstore ROM?
And so as to be clear, I should flash the superstore ROM first then update with levi's ROM?
Originally posted by Edius View PostInstall ROM 1.8 @900supersport from September first (with EBR1 and EBR2 for 4 or 6GB ...that's your choice) and his custom CWM.
ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
fran6,
it's not necessary to do all these steps, if you want to install TWRP recovery AND increase app space, but you are not interested in Lepi's ROM:
1 - flash with SP_flashtool ONLY modified EBR1 and EBR2 relevant to 4 or 6Gb (you can find them in any Supersport ROM)
2 - flash with SP_flashtool ONLY TWRP 2.8.1.0 recovery
that's all, you will remain with stock Rom v.2.0, if you want lepi's ROM, then flash this rom (you will not lose modded app space)
ROM update
Ok, will give a try...
Thanks guys.
Great ROM
Thanks a lot, Lepi! You performed a very nice and useful job with this ROM! Especially including NTFS support!I've installed this just now without wiping 'Data' for keeping my programs, and only 3 programs couldn't be found then, which could be easily and fast reinstalled (Aldiko Reader, Subway Surfers, and MinDig TV (which is a hungarian free-TV application)). Updating from 'U65GT_V2.0.2W_en_141231_mod Lepi' resulted a more precise battery status follow-up!
There are currently 2933 users online. 0 members and 2933 guests.
