4K@60Hz(FPS)
But it could be also the same problem because of the 10bit output and 8bit input at the HDMI at the TV... do we know which TV he talks about?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostBut it could be also the same problem because of the 10bit output and 8bit input at the HDMI at the TV... do we know which TV he talks about?
I solved my sound problem using SPIF optical cable. I think it was the ARC function of my TV that was not working properly :/
And also there is this that I found on youtube https://www.youtube.com/watch?v=VOHL8Pm6Ih4
He is playing 4k video from the Bluetimes Pro apparently.
So yes those boxes are able to pump out 4k.
4K@60Hz(FPS)
Originally posted by Rayzin View PostI just read the thread over and missed this part:
He doesn't mention what kind of tv it was but he did eventually get 4k to work.
Originally posted by Batfink32 View Post4k works at 30hz on my 4k tv but not at 60hz which it should as advertised. This seems to be because the Rk3288 is only compatible with 10bit colour HDMI 2.0 ports as is said on the open chameleon website. I believe some posters on here with 10bit colour HDMI 2.0 ports on here have managed to get 4k@60hz working. If you only have a TV with an 8bit colour HDMI 2.0 port then you will only get 4k@30hz.
It doesn't make sense why a lower bit (8bit) will not work but a higher bit (10bit) would work. This is not a Rockchip issue. Please see the wiki page here about HEVC decoding and you will see both 10bit and 8bit work. http://en.wikipedia.org/wiki/High_Ef...oding#Profiles - "The Main 10 profile allows for a bit depth of 8-bits to 10-bits per sample with 4:2:0 chroma sampling.[1][2] HEVC decoders that conform to the Main 10 profile must be capable of decoding bitstreams made with the following profiles: Main and Main 10". That means both 8bit and 10bit can be decoded.
Some further reading on HEVC - http://iphome.hhi.de/wiegand/assets/pdfs/2012_12_IEEE-HEVC-Overview.pdf. Go to page 17. Under the heading "B. The HEVC Profile and Level Definitions" it says - "Only 4:2:0 chroma sampling is supported." Only 4:2:0 for Main/Main10 requirements which the datasheet from the rk3288 Radxa board I referenced from above states as supported.
Now take all that information and lets look at the HDMI2.0 interface. Please look at the hdmi website http://www.hdmi.org/manufacturer/hdm...0_faq.aspx#146. You will see the chroma sampling rate 4:2:0 under 8bit and 10bit at 4k@60.
To conclude, rk3288 = able to HEVC decode 4k@60 at both 8bit and 10bit.
If you are not getting 4k@60 check to see if these things are in order; Your tv specs, your HDMI cable, and your box firmware.
I can report that I am able to get a 4k 3840x2160 @ 60fps signal from my
Beelink R89
to this 4K TV:
Samsung UE50HU6900
Although I had two signal drops where I saw a black screen for around 2 seconds in the first few minutes after setup, it looked stable afterwards.
I do have micro stuttering with 4k 25fps material, but 4k 60fps material (h265 encoded) seems to work fine (no visible stuttering)Beelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
Screen: Samsung UE50HU6900 - link: 3840x2160@60Hz 10Bit
Apps: MXPlayer, Rooted SSH/SFTP Daemon, scriptmanager, kbox2
(think: Public Display 4k)
Originally posted by Rayzin View PostYou are wrong. Unless the Rockchip datasheet is false, there is an H.265 decoder = 4k@60hz.
@Xinot. "Deep colour" in UHD Samsung TV mean exactly 10bit HDMI 2.0 mode.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostThere is major difference between decoding and displaying. Even if you can decode 8 bit content on RK3288 SoC its HDMI interface from unknown reason can not use this mode when display resolution is above 1080p. I know that it sound like an absurd but for now it is so. It might be associated with some hardware flaws.
@Rayzin.You are too much concentrated on RK3288 video decoder unit (VPU) capability that you have problem with understanding what I wrote about display interface. These are not the same thing. For example you can decode HEVC video (8 or 10 bit per sample) and by downsampling display that picture on CRT TV at 576i resolution through composite video interface (AV jack).
For now RK3288 HDMI output can only transmit 4k resolution video at 60fps when working in 10 bit per channel mode. Why is that? This is question for engineers working on that project but it might not be a software problem. Display interfaces are almost completly hardware based and there are only registers which can set some configuration parameters or read data sent from display. If there is no hardware to support 4k at 60fps and 8 bit per channel mode then it will never be otherwise.Last edited by Gormar; 02 March 2015, 10:41.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hi there. A quick question to the round of 4k 60fps enthusiasts here:
Can the RK3288 hardware-decoder handle h265 10bit streams?
Can the RK3288 hardware-decoder handle h265 yuv444 or yuv422 streams?
I'm at the moment encoding my videos with an x265 8bit enabled ffmpeg with yuv420.Beelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
Rk3288 HEVC decoder support Main and Main10 profiles. Therefor it should play video encoded in RGB101010 and YUV 4:2:0.
If you provide samples then someone will certainly test it.Last edited by Gormar; 02 March 2015, 10:40.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
whats RK101010 ? (couldn't find anything about it using google)Last edited by kaefert; 02 March 2015, 11:37.Beelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
There are currently 2584 users online. 0 members and 2584 guests.
