Just curious but what are the file specs of the raw file you are trying to encode? (size, YUV, format etc.)
4K@60Hz(FPS)
I'm joining together various different videos of various resolutions and framerates - thats what I use avisynth for - to unify resolutions and framerates, and to get smooth blending (function dissolve) between them.
It varies from 20MP Canon EOS pictures (though as of yet I'm only using the 8bit jpg's and didn't take a look at high bitdepth processing in avisynth, maybe I'll take a look at vapoursynth for that) to low-resolution dvd-quality video clips.
What do you mean would help reveal if a problem with 8bit video playback is hardware or software related? What problem do you mean? The only problem I have observed is that video framerates not matching the display-connection refresh-rate will produce stuttering (at least for 25fps video played via a 60hz hdmi connection)Beelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
Screen: Samsung UE50HU6900 - link: 3840x2160@60Hz 10Bit
Apps: MXPlayer, Rooted SSH/SFTP Daemon, scriptmanager, kbox2
(think: Public Display 4k)
From what I've read in the previous pages of this thread, it seems that the
RK3288 does only support hdmi connections with 4k@60fps when the TV will accept 10bit color depth.
And from my experience when you are lucky enough that your TV does support that you will get stutter if the framerate of your video file does not mach this 60fps of the hdmi connection.Beelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
Originally posted by kaefert View PostFrom what I've read in the previous pages of this thread, it seems that the
though it would be quite interesting to know if that lack of 4k@60hz@8bit hdmi support is hardware or firmware relatedBeelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
Originally posted by Batfink32 View PostMy TV which has only 8bit 4k HDMI ports does not even give me the choice of 4k@60hz in the RK3288 settings, I can only get 4k@30hz option even with an HDMI2.0 cable. Are you guys talking about this or how videos are encoded?RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostSorry, but this thread was hijacked when we achieved consensus that to use 4K display at 50/60fps we need TV which accept 10bit colour values in that mode. Then it is a shame to use videos encoded with 8bit color depth which will be interpolated before sending through HDMI interface as 10bpc. But as it came out encode video at 10bit color depth using libx265 isn't trivial task.
Then we have kaefert who explicitly states he has used 8bit 4k@60 without any issues. Or did you not see that?
@Rayzin - I never stated that I have an HDMI connection of 4k@60fps@8bit --> 4k@60fps HDMI connection will only work when on 10bit (from what I have observed) what we where talking about with 8bit and 10bit was about video encoding, not HDMI connection.
So what I'm trying to achieve is to get my videos encoded with 10bit to actually make use of all that extra room in the color space.
@Batfink32 could you maybe share a screenshot of that "bad screen tearing" - I don't know what you mean by that (I did not try to configure my HDMI connection with 4k@30fps though).
update: never mind Batfink32, I've looked at the wikipedia article what screen tearing meanshttp://en.wikipedia.org/wiki/Screen_tearing (that sucks! lucklily I don't have it)
Last edited by kaefert; 06 March 2015, 07:43.Beelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
Originally posted by Rayzin View PostThen we have kaefert who explicitly states he has used 8bit 4k@60 without any issues. Or did you not see that?
On the other hand no one officially announced that RK3288 HDMI interface cannot output 4K at 50/60Hz and 8 bit color depth but reports aren't favouring other conclusions.
As far as I know only one person (jeorentie) might use TV which as per instruction manual could support 4K 50/60Hz mode only in 8 bit color depth and yuv4:4:4 but even this isn't 100% confirmed.
After some more reading I might have another theory why some TV claim to support HDMI 2.0 interface but cannot cooperate with RK3288 at 4K resolution and 50/60Hz refresh rate. Maybe these TVs doesn't support 4:2:0 chroma subsampling but RK3288 can only use that and not 4:4:4 (no chroma subsampling). In accordance with HDMI 2.0 specification this resolution at that frame refresh rate can only be achieved with 8bit color depth and yuv4:2:0 or yuv4:4:4 or RGB. At 10 bit depth and higher from these two chroma subsampling modes only 4:2:0 is supported. Panasonic TX-xxAX630E instruction manual claim that in 4K at 60Hz HDMI mode it use no chroma subsampling (4:4:4) therefor if RK3288 HDMI interface support purely 4:2:0 chroma subsampling then only 30fps is possible and not even in 10 bit color depth mode but in HDMI 1.0 mode.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
I've got some mixed thoughts about RK3288 and 4K at 60fps. It looks like even experts aren't sure about HDMI output capabilites.
For example Openhour Cameleon FAQ states that RK3288 only support HDMI 2.0 mode without chroma subsampling (4:4:4) and there is no mention about required 10bit color depth. But in that case Panasonic TX-xxAX630E should work with RK3288.
I think it is neccesary to completly reveal which modes RK3288 HDMI interface can realy handle. If that will not happen then it would be quite hard to assert compatibility between this SoC and any UHD TV and more misleading information will surface.
If someone whose UHD TV can work with RK3288 and 4K resolution at 50 or 60 fps would send me registry file from HDMI interface I will be glad and maybe capable to determine in which mode it is realy working.
To do so you must have root access and execute this command:
Code:[I]cat /sys/kernel/debug/rk3288-hdmi/hdmi > /mnt/sdcard/hdmi_regs.txt dmesg|tail -65 > [/I][I]/mnt/sdcard/hdmi_dmesg.txt [/I]
Note: Before executing second command (pressing Enter) suspend your device for a moment.
Other option is to run my program which will display some HDMI interface settings read from register values stored in /mnt/sdcard/hdmi_regs.txt file. Download and extract atached file put it in the /data/ directory and set execution rights to that file. The enter command: ./RK3288_HDMI_reg.elf
Grab the outputed information and share it here.Attached FilesRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Hey there Gormar!
Here sys_kernel_debug_rk3288-hdmi.txt you can find the contents of
Code:/sys/kernel/debug/rk3288-hdmi/hdmi
And here dmesg_hdmi_snippets.txt are parts of the dmesg output of my Beelink R89 that looked relevant to the HDMI connection for me.
And I've got a question for everbody who is using an RK3288 media player with 4k @ 60Hz --> what HDMI cable are you using, and where did you buy it? The cable that came with my Beelink R89 does work in general, but still gives me signal drops sometimes (up to 2 seconds of a black screen). I've tried a few others, but all of them where much worse (more of 50% of the time signal drops & black screen) then the one that came with the box.Beelink NETXEON R89B V3.1 RK3288/A P6335/2G/16G
My post here is to bring some bad news.
I contacted Rockchip and asked if 8bit was supported 4k@60 and the answer was no, only 10bit. I am waiting for a reply of follow up questions and I'll post them here. It's really disappointing for those who only have 8bit 4k capable tvs. But after all this confusion, lack of transparency, misleading information etc. I am glad to have closure on this issue.
There are currently 2824 users online. 0 members and 2824 guests.
