The SDK is another story...
[KERNEL] Compiling a working kernel (android) - WIP
Originally posted by GJayJayG View Post
The SDK is another story...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by GJayJayG View PostDear Bob,
Thank you for your advices.
EDIT, REASON: found solution;
Would it be possible to also package TWRP inside ROMs, using ImgRepacker or other method. Do you have a few pointers on that?
Originally posted by Finless View PostYes just replace recovery.fex with the TWRP and repack the AllWinner image.
(I'll try to integrate this into all future ROMs)
also that also did the trick, but with some more steps
Can I also download it somewhere without using a (un)social network ?
EDIT
Ok, google is my friend http://www.google.de/search?q=boot-repacker-401+zipRK3288 Devices
Originally posted by GJayJayG View Postyep, thx I had given it a try before you replied
http://boot-repacker.blogspot.ch/
Hi GJayJayG, Finless!
I'm trying to compile the kernel for Tronsmart AW80 with USB touch screen enabled and USB-to-Serial support enabled.
As a first step I tried to compile the kernel without any modifications using instructions from the first post (and the source from the links provided in first post - didn't find the newer\better kernel source).
The kernel compiled without issues, but I didn't build the full android (I tried, but it failed).
Then I used imgRePacker 2.05 tool under Windows (http://forum.xda-developers.com/show....php?t=1753473) to unpack firmware image, then unpack boot image (after that i get kernel+ramfs). Then I replace kernel file with bImage file from output dir of my built kernel, repack boot image and the firmware image.
After that I flash the image with PhoenixCard and get the black screen after the boot splash (no boot animation etc).
If I just unpack\repack without replacing the file everything is OK (so I think imgRePacker is not the issue).
But because the size of my kernel is a little bit larger I'm not sure if it repacks correctly (although if I then unpack again and do binary compare of the files - everything matches)
I'm using sunchip-CX-X8-A99-A80-6335-20150323 ROM.
Any ideas what is wrong with the kernel or repack process?
Still no luck with making kernel work.
I am able to successfully compile kernel using instructions in 1st post and exactly the same system in VirtualBox.
Then I replace kernel in ROM (I tried with draco_aw80_dovless_1.13.img) using imgRePacker (unpack firmware, unpack boot.fex, replace kernel inside boot.fex dump with compiled bImage file, repack boot.fex, repack firmware) and flash it.
System hangs on boot screen.
Tried also to replace modules in /system/vendor/modules with compiled ones and nand.ko inside boot.fex also.
Still no luck with booting.
What am I doing wrong?
I tried also compiling the whole ROM (using 1st post instructions) but don't know what to select in lunch.
If I select default item (aosp_arm-eng) I get an error after extract-bsp command: "unknow CHIP_VERSION"
If I select any of the options "jaws_*" - I get an error after extract-bsp (it cannot find and copy bImage and modules)
If I proceed with "make -j8" command I get an error soon after the process start: "MODULE.TARGET.EXECUTABLES.fsck_msdos already defined by external/fsck_msdos"
Actually I think I don't need building full Android, just need to figure what's wrong with the kernel or boot.img.
Can anybody help please ?
There are currently 2662 users online. 3 members and 2659 guests.
