PIPO X7 with KODI 24p playback
Originally posted by noggin View PostDo we know that the Ivy Bridge graphics in the Z-series Baytrail SoCs have the 24p fix?
The Baytrail N28xx series "Celerons" have the fix, but the original Ivy Bridge Celeron, Pentium and Core i3/5/7 models had the bug.
Originally posted by goujam View PostMy baytrail-d (j1900) doesn't have the bug. If only I could get openelec on this it would be easy to check as I think its a windows issue
Have you tried disabling Windows Aero? ISTR that caused issues with 23.976p in some cases on Windows 7.
Originally posted by noggin View PostYep - OpenElec on this thing as a dual boot would be amazing.
Is there a definite way to make sure its off in windows 8.1 as the task bar was still see through when I made that change.
I'm also hoping openelec on this device would allow HD audio. As with windows and this processor its limited to DTS and did. My j1900 with openelec does HD audio no problem
Yep - am hoping that the Z-series SoCs are like the N-series and J-series Baytrails and have HD Audio functionality in Linux (and thus OpenElec) even if they don't in Windows because of PAP/driver issues.
I'm guessing the HD Audio functionality could be checked with an Ubuntu build - and people are getting Ubuntu working on 32bit UEFI set-ups (Transformer T100 and Meegopad T01) with these CPUs. When mine arrives I'll have a play. (Should be able to boot an Ubuntu Live USB with a bit of boot loader tweaking I believe)
Originally posted by WeK05 View PostKodi with "sync playback to display" option checked can show the actual refresh rate that is being output under "sync to screen information" in "codec info" overlay. MadVR OSD will better show the information, but I am not sure how well MadVR can run on these devices.
Originally posted by goujam View PostYeah its next to S, I have ever increasing missed speed and sync are +0.1% ( or something like that) and error goes to 0%
Originally posted by WeK05 View PostIf you are playing 23.976fps content and the sync is +0.1%, either the EDID info that the device is getting is incorrect or your TV likely doesn't have true 24p playback (it displays everything at 24Hz).
Originally posted by goujam View PostThat's the thing my TV and avr support 24p in windows there is a 23 and 24 for resfresh rate. And the same setup works fine with openelec on a j1900 system from down stairs. It's only since using windows 8.1 with kodi I've had this problem
Originally posted by WeK05 View PostInstall Monitor Asset Manager - http://www.entechtaiwan.com/util/moninfo.shtm and check what modes are being read from the EDID for your TV.
In windows when I look at the monitor page I have only show refresh rates supported by the monitor and 23 and 24 hz are both in there.
I'm not sure the edid information is getting through correct I'll have to try and work out what I'm doing with it. Is it just a case of editing the file to include a modeline for 23.976?
There are currently 4326 users online. 0 members and 4326 guests.
