So I got fed up and fixed it! Now you can have an English recovery drive.
First you should have made a recovery USB drive per my instructions here:
http://www.freaktab.com/showthread.p...th-the-Pipo-X7
Download this this ZIP:
http://www.freak-tab.de/finless/pipox7_boot.wim_en.zip
Instructions:
1) Unzip this and you will have a file called boot.wim
2) Stick your recovery disk you made into your PC and open it.
3) Go to the sources folder and rename boot.wim to boot.old
This is so you have the original if needed.
4) Copy the boot.wim from this zip into the sources folder.
5) Now use your PC and EJECT the USB drive. This is important so you do not corrupt it.
That's it! Now when you boot your recovery drive it will be in English
Enjoy,
