English Language Recovery USB Disk
Originally posted by blinkone View PostGot it now thanks Bob, I made the recovery usb stick following your instructions. I go into sources to rename boot.wim to oldboot
but there is no boot.wim in sources there is only the below items in sources
$PBR_Diskpart
$PBR_ResetConfig
install.swm1
install.swm2
install.swm3
(oops, I see it's already been said; my bad)
Originally posted by gkool View PostIs there any chance in the world that this would work for voyo mini pc as well? It could be the same file that has to be replaced, right?
I'm just going to take pictures of the options, put back the original boot.wim and choose the chinese equivalent.
UPDATE: I just put back the original boot.wim file and following the pictures of the english version I chose to reset the pc and the partitions. Lets cross fingers...Last edited by Kiavik; 08 March 2015, 21:57.
Originally posted by gkool View PostHow has it gone? I am still waiting for voyo to arrive but it seems that pipo has so much more support from the community...
I managed to reinstall windows on my Voyo, here you can find more: http://www.freaktab.com/showthread.p...ery-media-test
One thing is sure: the recovery partition is corrupt or my media got corrupt while creating it.
We had a problem with the server, now it should work again (I only started the download)...RK3288 Devices
- Overview BOX (LINK !)
apply same procedure dual boot Pipo X7S?
i apply this procedure dual boot Pipo X7S but i can't dind boot.wim in sources folder.
Originally posted by Finless View PostHey folks. So as I am playing around and using the recovery disk to restore, have the recovery menus in Chinese when booting from a recovery USB stick is terrible! Even when it boots and you select US English, the menus are still in Chinese. This is because of the DLL's and other stuff being made from a Chinese build.
So I got fed up and fixed it! Now you can have an English recovery drive.
First you should have made a recovery USB drive per my instructions here:
http://www.freaktab.com/showthread.p...th-the-Pipo-X7
Download this this ZIP:
http://www.freak-tab.de/finless/pipox7_boot.wim_en.zip
Instructions:
1) Unzip this and you will have a file called boot.wim
2) Stick your recovery disk you made into your PC and open it.
3) Go to the sources folder and rename boot.wim to boot.old
This is so you have the original if needed.
4) Copy the boot.wim from this zip into the sources folder.
5) Now use your PC and EJECT the USB drive. This is important so you do not corrupt it.
That's it! Now when you boot your recovery drive it will be in English
Enjoy,
Just made another recovery usb disk Bob,, Copy Recovery box ticked,
i used a 8GB usb stick done the recovery with no errors the recovery takes up 5.3GB
still the same there is no boot.wim
sources folder
$PBR_Diskpart
$PBR_ResetConfig
install.swm1
install.swm2
install.swm3
In the recovery usb stick i made iv got a
boot (folder)
efi (folder)
sources (folder)
bootmgr
bootmgr.efi
reagent
Arrrr now I see it,, I had to untick hide protected operating system files.
Sorry for being a pain :-)
RK3288 Devices
There are currently 2967 users online. 0 members and 2967 guests.
