Firmware for x4 s805 box
Originally posted by Bartjunited View PostHi I have a Sumvision x4 s805 (Amlogic) box and want to know if I am running the latest firmware and where I can get a firmware update.
I have attached a screenshot of the firmware I am currently running.
Thanks in advance , Bart
[ATTACH=CONFIG]9890[/ATTACH]
I'm only interested in Kodi and not other Android apps, so I am now running Kerber's OpenELEC port for the TV110, which works superbly on this box.
If you want to stick to Android, you can root the box and also install the latest stable version of Kodi (14.0) as it comes unrooted and with Kodi 14.0-alpha1 (which works pretty well already).
There's a big thread on Kodi.tv forums here http://forum.kodi.tv/showthread.php?tid=208233
Originally posted by bobones View PostThere's no later official firmware from Sumvision that I am aware of, but there are probably other compatible f/w around.
Thanks a bunch for your reply
sorry more noob questions
Where can i find and install Kerbers OpenElec
What do you mean by Tv110 - is this the model reference for these S805 boxes?
Why does the box need to be rooted to install Kodi?
Thanks again
Bart
Thanks again
Bart
The TV110 is a similar S805 box and is the original target of Kerber's port. Our X4's work with the same port with just a change for the remote control configuration.
It is not necessary to root to install Kodi, and I did not say it was. I merely pointed out 2 things you could do to upgrade it.
Originally posted by smoothfreeze View PostHey man, what are the differences between xbmc/kodi and OpenELEC? Can you shoot me a link to it too? Running the TV110 too, loving it so far! Thanks in advance!
As always flash at your own risk!
Originally posted by bobones View PostOpenELEC is a small Linux distro with the single purpose of running xbmc/kodi. You are running Android on your box which is a multi-purpose system and Kodi as just one of many apps. With OpenELEC you only get one app and that's Kodi. Because OE is streamlined just for Kodi, Kodi runs faster and smoother than under Android. If you only ever use Kodi on your box, you might like OpenELEC. Otherwise, if you dabble with games and other apps, stick with Android. I'm not going to spoon feed you on how to install OpenELEC on the TV110 but the most recent stable images are at http://amlinux.ru/image/5.0.0/
Thanks againffor the heads up about openelec. I've used it plenty with the pi and found it very good.
I can'tffind a clear guide from your thread on how to install openelec on Androi.
I see ffrom your image link that there are openelec images for MXIII and x4 is that right
Thanks Bart
Originally posted by Bartjunited View PostThanks againffor the heads up about openelec. I've used it plenty with the pi and found it very good.
Thanks Bart
This is the basic guide I wrote before http://forum.kodi.tv/showthread.php?...029#pid1852029
Originally posted by bobones View PostThe TV110 images are the ones to use for the Cyclone X4.
can Openelec be installed on a MXiii (square) running S802?
And if so can I use the same method?
the link you sent for the images showed an MX3 image for openelec?
Originally posted by Bartjunited View Postthanks guide looks good and in the main to flash the image looks straight forward I just hope i dont have any issues :-)
There are currently 7221 users online. 3 members and 7218 guests.
