Can you guys help me because i'm out of ideas... Sorry for my bad English
Hard bricked Pipo S1 Pro
Hy guys. My Pipo got hard bricked so i did a little research how to unbrick it. So tablet did not respond when i push the power button or any other button. My comp didnt recognise the tablet when I plugged it into computer. I opened it up and short pinned NAND chip. Then computer detect it but didn't install the drivers for it so i installed it manually. Computer detect it as a Rockusb Device. In RKBatchTool i have a blue box, I try to use switch button but got an error. In RKAndroidTool v.1.37 on the bottom writes "Found Rkandroid MaskRom mode" but when i press "EraseIDB" after few second message pops up "Erasing IDB failed".
Can you guys help me because i'm out of ideas... Sorry for my bad EnglishTags: None
Sounds like the same problem I have with mine, memory chip is bad. Nothing you can do to replace it, so you might want to read up on how to boot from and sdcard and see if that will work for it.
Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Originally posted by Milan As View PostIt's hard bricked, I can't turn it on and use memory card
If you want to try what I did to make mine work for a while at least, you can go through a long and painful process of resetting, plugging to usb, erasing nand, resetting, shorting pins for mask rom mode, flash rom, flash misc.img and booting, or some combination of steps to make it work. It's hard work and may not result in anything for your tablet if you only have one nand chip.
Or you could buy a new tablet, they make better ones these days. Pipo seems to have a problem with their memory going bad.Currently Inactive on Freaktab.com
Would help to know your phone's chipset. If its MTK then I can help.
You cold also google how to unbrick / fix a bricked Android device .
Display: 7", 1024*600 (16:9)
Touch Panel: Capacitive 5-touch
CPU: Rockchip 3188 Cortex A9,1.6GHz,Quad-core CPU+Quad-core GPU
RAM: 1GB DDR3
Storage: 8GB flash memory
Operation System: Android 4.2
Camera: Front 0.3M, back 2M
WiFi: 802.11b/g/n
Internal 3G built-in: No
External 3G support: Yes
Bluetooth :No
Others: G-sensor, Micro SD slot, mic, speaker, mini HDMI output
Multimedia:Audio, Video(1080P), Photo,ebook,game, email, internet…
Battery capacity: 3200 mAh by 3.7V
That's all I know
There are currently 16989 users online. 2 members and 16987 guests.
