I've added some low profile heatsinks directly to the existing thin metal heatsink (after peeling off the sticker/plastic cover) using standard thermal glue and some old heatsinks left over from a modified graphics card cooler. Currently maxing out at 63oC with 22oC ambient. I could probably improve it further if I removed the original thin heatsink and attach directly to the chips but this seems to work fine. I'm very happy with this little unit!
Pipo X7 internal construction and heat dissipation
Heatsink mod
Hi. When using hw monitor i get some strange cpu clocks and my Pipo get very hot instantly. This is when using Chrome playing Utube. Not when running stresstest like Aida 64. Look at clock speed on picture. Thanks Knievel Edit. Im not able to upload in full size. Anybody know how?You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by knievel; 04-13-2015, 22:33.
Originally posted by noggin View Post
Yep - looks like the Minix and the Zotac both have metal heatsinks...
It's just unprofessional for not considering about heat issues.
A large heatsink is necessary for this platform since the CPU power consumption could go high up to 6.5W.
Manufacturer can't expect average users to perform this kind of self-mod, 99% of users are not going to do that.
After all... you get what you paid for...
You mean like this http://freaktab.com/forum/tv-player-...er-heard-about
RK3288 Devices
- Overview BOX (LINK !)
Hi there !
I got a very nice and simple solution to get rid of the heat in the Pipo X7. I just bought a 4mm height thermal pad on **** ($10) and then put it between the motherboard and the back plate. Results are very nice ! does ran a lot of demanding programs for the CPU and GPU, the plate goes a little hot, not the motherboard. Good !!
http://mo5.com/mod_thermique_pipox7.jpg
Cheers !
Philippe.
Cheers !
Philippe.
I have 2 pipo's.
Both with 5mm thermal pad under the motherboard, and one of them also got a aluminum heatsink (40x40x13 mm) on top of stock heatsink/plate.
The heatsink doesent make much differense. I think its because i have no fan inside to blow air on it.
Like you say i think a thermal pad does the trick. And its very easy to put on. Instead of risking to damage anything when taking out the motherboard.
Knievel
Originally posted by ultrabit View Post
Have you got a link to the one you used?
It took only 5 days with free shipping (China post i think) to Norway. And its all i need so far for my x7.
Knievel
Could u tell me about hight of metal heatsink? I'll try to do like u.
Thank you.
Originally posted by KYLE KWON View Post
Hello,
Thank you.
thanks,
N
Cheers !
Philippe.
There are currently 2319 users online. 4 members and 2315 guests.
