it looks like Rockchip working hard on chromiumOS integration and VPU
    some libv4lplugins for chromeos any idea what is it?
    No garanty that chromium os will run fully satifactorily on any 3288 touchscreen device soon just because of a few visible commits signed by rockcrap...
      Any idea how can I build ChromeOS ?
      There must be some kind of run this And I will build whole ChromeOS for you script somewhere
        I'm sure there are detailed instructions on the site which can be found with a little googling. Probably easiest to build using Linux on the target device itself (as in Linux for rk3288 rather than cross compiling from a pc running Linux).
        I noticed some time ago that the source for including the widevine DRM CDM in chromium for android is there. The required binary library is all that is missing. At least theoretically you should be able to build the chromium browser for android from source and include this library. Then you should be able to use Netflix in HD in the browser. I've been wondering ever since if some of the widevine libraries floating around which are from level 1 drm android devices could be used for this purpose. Haven't tested it though.
        Cheers,
        -SB
        Currently using U-BOX R89 with mo123 v1.6.
        Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
        Pipo M9S -- CrewRKTab custom rooted 4.4.2
        RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
        ----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
          @Miskol
          Might give here a look: https://github.com/RockchipOpensourc...id-kernel-3.14. I would stick with 3.14 for all builds. Kernel migration for pretty much everything seems to be headed in this direction.
          ----cappybob
            Originally posted by cappybob View Post
            @Miskol
            ----cappybob
            These sources, they're good for android, Linux, and chromium OS? I don't really understand why there would be a preference for vpu development on chromium vs Linux. Wouldn't most chromium OS drivers be compatible with Linux running the same kernel, or is there more of a difference than that?
            Thanks,
            -SB
