Can it be continuously on. Does this tv stick has overheat issues I should be aware of?
Can I use MK808B Plus 24/24 7/7?
I have ordered the MK808B plus .. still waiting for it to arrive. I am planning to use it as a download torrent and media server which will run 24 over 24 and 7 over 7...
Can it be continuously on. Does this tv stick has overheat issues I should be aware of?Tags: None
Originally posted by yeahman45 View PostI have ordered the MK808B plus .. still waiting for it to arrive. I am planning to use it as a download torrent and media server which will run 24 over 24 and 7 over 7...
TTorrent Pro works fabulous....and with it able to monitor a folder for files it is fantastic.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
MK808B Plus CPU temperature
@prahjister: Did you actually track CPU temperatures via some app? I've installed Xposed framework & "CpuTemp in statusbar" module, and my MK808B Plus is at 45° Celsius just after it boots to Homescreen, after some time of just sitting there at Homescreen it 52-55, and if I play Youtube video, or 720p/1080p hardware accelerated in MX Player or XBMC temperature is at 67-70. I wouldn't call that "very little heat". Yes the casing/plastic is not to warm but considering that my Nexus 4 after 30 minutes of playing the same video files is at 32-34° (which is the same temp it's usually on while using my phone for surfing, chat etc) MK808b Plus's SoC is almost burning up.
I'll probably try buying some miniature heath-sinks and thermal pad to lower the temps if possible, because I don't see this surviving a month of sitting idle or watching LOTR movies marathon in one go.
There are currently 1877 users online. 3 members and 1874 guests.
