Box came with 108k4 installed so hoping there might be a more up to date firmware somewhere.
MXQ S85 from Gear best
There was a 109k firmware posted somewhere here, i am sure you can find it with google. But it was reported that MK808B Plus roms also work on the MXQ but without ethernet, so you if you use wifi you can just use the finless rom or the openelec build for MK808B Plus.
Kerber from xbmc.ru also has an openelec build in development. You can find it here http://www.amlinux.ru/image/devel/
Originally posted by dahat View PostAppreciate the reply, found the Open Elex build and likely to try that but lack of Ethernet is a concern.
Seems to be very little going on for this box
There are currently 3502 users online. 0 members and 3502 guests.
