How to change the default android wallpaper of the ROM (Finless 1.6) (wallpaper "the beach")
    Hi!
    Im using the Finless ROM 1.6.
    The default wallpaper is "the beach".
    Have a file that I can edit to change the default wallpaper to show?I need it because I'm doing an application to show what is the default wallpaper, not the current. (for personal use)
    Thanks!
    Originally posted by cloud View Post
    Hi!
    Thanks!
    Long-click the beach wallpaper.
      Thanks for the reply, but not is to change the wallpaper.
      Example:
      When we installed the ROM Finless, the default wallpaper is "the beach", how do I to when install this ROM the default wallpaper to be another?
      Thanks! =)
        You ahve to take apart launcher2.apk and change the code.
          Re: How to change the default android wallpaper of the ROM (Finless 1.6) (wallpaper "the beach&quot
          nope its the framework-res. apk
          Verstuurd van mijn GT-S5660 met Tapatalk
          if you love my work please buy a coffee
          <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
          </form>
            Re: How to change the default android wallpaper of the ROM (Finless 1.6) (wallpaper &quot;the beach&quot
            if you open this apk with 7zip, open the folder res.
            then you see folders like drawable-mdpi or drawable-nodpi.
            search in this folders for default_wallpaper.
            no drag a new wallpaper to this folders and and close zip.
            cope now the modded apk to framework folder and reboot.
            if it not works you do something wrong. because i did it several times for my roms
            </form>
              Checking... =)
                Found the default-wallpaper.jpg !
                But, if I delete this image, the default wallpaper will turn black or giving error in the launcher?
                Thanks! =)
                  you must add another one in the place
                  </form>
                    now its up to you to find one thats best fit for your tablet
                    </form>
                      My UG802 dont boot anymore after changing the image with NinjaMorph.
                      It starts, go to LOADING screen and do not pass this screen.
                      What can I do to re-install the ROM?
                      My ROM is 1.6 Finless.
                      Thanks!
                        Fixed with this tutorial:
                        Thanks! =)
                          don't use ninjamorph its crap.
                          learn it by do itself, by modding apk.
                          </form>
                            And this? :
                            APK MANAGER:
                              you need this if you want change the smali files.
                              if you only want change png's then you must copy the apk to pc and open the apk with 7zip (not extract) and drag the new png's with the same name too the correct folders in /res.
                              you get it?
                              </form>
