Replacement remote vega s89-h
    No luck finding t his
    Originally posted by jacadito View Post
    No need to teach it. Just plug the dongle in a USB port, press left and right mouse button together to pair the remote and the dongle, and it works (you will then only need to change a detail in a text file to make the home button work).
    If you also want to use the remote to control other devices like your receiver or TV or cable box it will easily learn from the original remotes.
    Just Google it, you'll find a lot of info, including the required adaptation to make the home button work as well as YouTube movies showing how to learn IR from other remotes.
    I ordered mine directly from the Mele shop on Aliexpress.com.
    Maybe I searched for something wrong, but I cannot find a guide on how to turn on the IR learning for the remote, can you help?
      Works like a charm.
        Yesterday I've bought the Mele F10 Deluxe. Very good option for our device...
