If there is a way of resetting on boot ?
MK808B_Plus USB Ethernet stops working after few days.
Originally posted by Johnoo View PostSticks come back from customers with Ethernet not working. I have one running at my place but not stopped thus far, seems to be random.
If there is a way of resetting on boot ?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by prahjister View Postso rebooting doesn't fix the solution i take it. Without access to the device while it is in the state it is it is difficult to diagnose. I would trust CT input and try to see if that fixes the problem.
Rebooting does not work, get the 2 small boxes in the corner but no sync, to get it working again have to re-flash firmware.
The TWRP uploaded image will give access to the issue, in that state for diagnoses.
I would try CM11 or 12 that uses Android'd native ethernet services (introduced with Lollipop), and I have support for both ethX and usbnetX devices.WeTek Play
Recoveries: CWM | TWRP
Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
Misc: Unbrick WeTek Play
Originally posted by ChristianTroy View PostI would try CM11 or 12 that uses Android'd native ethernet services.
Originally posted by prahjister View PostI have your IMG but my SD card reader died. Got a USB reader at work. Will bring home tomorrow
Once flashed Ethernet does not sync,
after factory reset Ethernet starts working again.
There are currently 1918 users online. 2 members and 1916 guests.
