MINIX X7 KitKat 4.4.2 CE ( Community Edition 2.2.0 )
    MINIX Forum "Community Edition" Kitkat 4.4.2 for X7
    OTA;
    For everyone that has installed "Community Edition 2.1.0";
    - You will recieve an OTA opdate automaticly.
    - You dont have to flash anything, just wait till the update screen shows.
    For everyone that does not have "Community Edition 2.1.0" installed;
    - You need to manualy flash this firmware with the USB Flashtool
    - All the tools will be provided in the download .rar file.
    The future of CE;
    This is not realy a CE release anymore.
    This firmware is build as an "Official MINIX" release, so it has all proper MINIX logo's and background.
    The reason we release it under "custom roms" is beqause MINIX has to approve it first.
    Hopefully we can copy this topic to Official section soon. ( or we might do that on next release )
    Changelog (2.2.0);
    - Huge HLS revision
    - Camera brightness/saturation fix
    - TCP buffer adjusted
    - Network fixes
    - Powermenu, removed power off. (x7mini branche )
    - HDMI changes
    - MINIX Official build
    Other;
    - Finisched X7mini branche ( currently available: X7,X7mini)
    - Preporations for X5 serie branches for future builds
    - rk3066 random mac fix
    Old Changelog (2.1.0)
    - sleep suspend fixed( wakeup from USB Remotes / IR remote / Powerbutton )
    - fully renewed audio bitstream system + audio input fix ( show usb audio input devices )
    - Screen settings all on one page
    - aditional VPN/networking config ( IPIP,L2TP,PPP )
    - removed PIN for VPN settings
    - VPN wifi hotspot fix
    - Removed google searchbar from desktop
    - long press menukey to hide/unhide systembar
    - update drivers for future X5 branch
    - recovery show UI + Null pointer fix
    - USB storrage announcements framework renewed
    - wifidisplay / miracast HDCP key integration ( not functional yet )
    - libffmpeg and RKffplayer updated to version 8-12
    - fixed RKexplore app
    - fixed WifiDisplay app
    - Small HLS fix ( not much yet )
    - Updated Gapps ( Google Apps )
    - Google sync issues fixed
    - New kernel logo / bootanimation ( add KAR )
    - a few others
    Old Changelog (2.0.0);
    - recovery/OTA fix
    - static ip bug fix
    - video player/hls fixes
    - security vulnarability fixes
    - init.d support
    - camera brightness fix
    - freeze after uninstall app fix
    - HDMI patch for DRM apps
    - DDR optimalisation ( not overclock )
    - Multi user support ( not fully working yet )
    - Dual input devices frees/crash fix.
    - new kernel logo
    - etc.
    Download link:
    http://www.minixforum.com/downloads/...141025-220.rar
    WARNING!! WARNING!! WARNING!! NOT EASY TO GO BACK TO 4.2!!
    (You need to use RK flashtool, do not try to flash it like an OTA update.zip !)
    Available Updates:
    Kitkat CE - root update
    Kitkat CE - unroot update
    To install the available updates (this is not for the Firmware!) rename the downloaded file to update.zip and place at the internal flash drive root or USB stick root, android will find the update and request you to install.
    From the MINIX Forum Developers Team;
    @gufone
    @KAR
    @HardwareGuru
    Also thanks to the MINIX Engineers, without them we would not come this far!
    thank you sir
      OTA update and root done in about 15 minutes (including download time). Excellent work @HardwareGuru, @gufone and @KAR.
      A few hours of testing has revealed nothing out of the ordinary. Audio is fine (DD/DTS passthrough works), the system feels very responsive and all my old settings seem to be intact.
      NVidia Shield TV 2015 16 GB || Stock
      NVidia Shield TV 2017 16 GB || Stock
      Buy me a beer?
        Thanks Molle!
          Thinking about trying this on my UT2 Ugoos (RK3188T)....think it'll work?
          FLHT = Harley
          HEMI = 2010 Dodge Challenger SRT
          Cause I've been asked.
            The kernel might crash on the "T".. allthough i never tried..
            How many GB storrage you have? you need at least a 16GB nand flash chip.
              Thank you HardwareGuru
              Thank you 2.2.0 downloading now, hope mic jack is working..
              I'm back working GREAT except Old pain MIC JACK is not working, Please any small update to fix ?
              Last edited by Nam; 04 February 2015, 02:21. Reason: came back after installed ROM
                update made yesterday by ota, all working fine.
                only to note:
                - need to re-root the rom
                - need to reinstall framework in xposed for fake wifi apk
                good job
                  It's 32GB internal...if I try it i'll post here what happened if you want....
                  FLHT = Harley
                    only to note:
                    OTA upgrade went flawlessly yesterday but I also had to re-root and also redo my /system/usr/keylayout remote mappings again. Everything else was as it was before the upgrade and it made it nice and painless.
                    I have XVolume from xposed framework and it seems to still be installed and working but I guess I need to double check to ensure I still have 45 volume steps instead of the default 15.
                      how new is the kernal?
                      im using the quickshot v3.1 right now without issue and am hesitant to switch but if the kernal is from minix and then tweaked is it a new kernal? and if this is so new why is it still 4.4.2? is a 4.4.4 coming out soon or is a 5.0.2 coming out instead.... lastly if this is just another flavor of the old minix rom from last year i will wait for quickshot to release the cyanogen mod edition soon!
                      Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
                      HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
                      ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
                        It is competely compiled from scratch.
                          micro stutter? or smooth as silk? that seems to be the only issue with most firmwares?
                            Minix Remote
                            Does this ROM has the correct button mapping for the Minix remote?
                              yes. it also supports several other remotes and I can confirm the A2 works as well as the default remote.
