MINIX X7 KitKat 4.4.2 CE ( Community Edition 2.2.0 )
    Originally posted by choekstr View Post
    yes. it also supports several other remotes and I can confirm the A2 works as well as the default remote.
    Thanks for the prompt reply. I'm currently on Wesser KK and I would like to know if there is any advantage of switching?
      can't say but the CE 2.2 version works flawlessly for me on my Minix X7 so if your Wesser KK isn't working as it should it is worth a go.
        I am on the original version and it has been working fine other than some random crashes specially with XBMC where the screen will go black when starting the app. But other than that not much issue.
          Has anyone had any trouble using the play store app.I installed this for a friend and he is telling me he cant register with google play store when he rnters his name and presses next it just hangs there.It is probably him doing something wrong just thought i woul d check here
            Not had an issue running 2.1 nor 2.2 with the play store. I am using this version on 3 minix X7's now and all allow me to configure and use the play store just fine. Sounds like user error or perhaps needs a re-flash.
              Thanks for the reply probably user error he not very technical lol
                Sounds like he's not connected to the internet to me....wifi on? Ethernet cable connected and turned on?
                FLHT = Harley
                HEMI = 2010 Dodge Challenger SRT
                Cause I've been asked.
                  how to root?
                  Originally posted by Molle View Post
                  OTA update and root done in about 15 minutes (including download time). Excellent work @HardwareGuru, @gufone and @KAR.
                  A few hours of testing has revealed nothing out of the ordinary. Audio is fine (DD/DTS passthrough works), the system feels very responsive and all my old settings seem to be intact.
                  Hi. Im a noob.
                  How do u root this firmware? Thanks
                    Originally posted by Android#8 View Post
                    Hi. Im a noob.
                    in the first page look root update fille and rename to update put it on a sd or flash drive and follow promt to install update on minix
                      Has anyone had any problem getting xbmctorrent to work on this firmware on xbmc.Worked fine on jellybean now cant get it to work on this
                        It ok got it working again
                          OK - Installed on a Ugoos UT2 with a RK3188T chip yesterday and it's all working fine. MKVs seem a little choppy so maybe I need to edit the advancedsettings.xml with some buffering lines? Any suggestions?
                          FYI - BT, WiFi, Ethernet all working fine for those that have UT2s with RK3188 or RK3188T chips.
                          FLHT = Harley
                            This is what I use. It is a slow and deliberate fill of the buffer for the least impact in playback while still filling up the buffer within say a minute:
                            Code:
                              <network>
                                <buffermode>1</buffermode>
                                <cachemembuffersize>257286400</cachemembuffersize>
                                <readbufferfactor>2</readbufferfactor>
                              </network>
                            I have gone up as high as <readbufferfactor>10</readbufferfactor> without any issues but when using 20, which is often recommended, it will often make the video stutter as these boxes just do not have enough processing power to do heavy I/O and playback at the same time.
                              Just installed this rom after my finless 1.9 wouldnt boot anymore. Works great!! Thanks!!!
                                The only thing I have found with this ROM is using a Minix A2 remote and installing an APK through ES File Explorer I can not select "Install" on the popup with the air mouse. I must use the dpad and highlight it and hit enter in order to continue and install. No matter what, the air mouse won't let me select that one specific dialog box.
                                Of course it works everywhere else and flawlessly lets me pick any other dialog box or file or icon with the air mouse. It's odd and not really a big deal and probably an ES Explorer issue but just pointing it out.
