MK809IV QuadCore NOT BOOTING
    I tried this firmware...
    百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
    And now my device does not boot anymore ... followed the instructions correctly ...
    Used this tool: Rockchip Batch Tool v1.8
    (held down reset and then connected, installed the driver and then opened up the program chose the FW and clicked restore - it sayd succcess IN GREEN)
    Now i have tried lots and lots of firmwares that i could find from this forum ... after trying like 6 different FW-s i still cant get it to boot ...
    This is the device:
    http://www.aliexpress.com/snapshot/6...63920713671635
    I have one more just like this that works ... could i get something from that ?
    ANY SUGGESTIONS ?
ID:	440108Click image for larger version
ID:	440109Click image for larger version
ID:	440110Click image for larger version
    try this
    Посмотреть и скачать с Яндекс Диска
      Ty ... it boots now but wifi does not work ... everything else is great
      How can i get the wifi to work ?
        try this =)
          Will not boot at all with this one ...
            mk809IV no va wifi
            [Quote = Murtpoiss; 279937] no arranca en absoluto con este ... [/ quote]
            yo tengo tambien un mk809IV comprado en aliexpress hace pocos dias y ha dejado de arrancar. Le he metido varias roms y algunas han hecho que arranque pero en ninguna funciona el wifi. Ya no se que hacer ni que probar: Cara
              Help me please ... maybe i can get the firmware from my other device that works ... i just dont know how ...
                Any other suggestions ??
                  Some here, I buy this one: http://www.aliexpress.com/snapshot/6...64715939138377
                  With just one diference, the wi-fi module I think.
                  Download more than 10 different firmware and none worked until now.
                  Note: sorry for bad English, it is automatically translated by Google.
                    Well, this one works fine for me - https://yadi.sk/d/xwJL6UspeJP6Y
                    But did not solve my problem, my device was locked in 1280x720 resolution and rescaled to 1920x1080 like before. I would firmware that had the actual resolution of 1920x1080.
                      i tried this ... wifi does not work but everything else works ...
                        I tried to track publications involving this firmware (D16BS_20150120.rar) to identify the source but without success. Probably your device to be some variation with different wifi module. I'll keep looking because I want firmware that is real 1080p. If I find something I will comment here.
                          Could you give me the links to some of these firmwares that you have tried ???
                          maybe you have already tried something that works for me ?
                            it will work
                              Thank you ... this solved my problem
