[ROM] [CyanogenMod 11] [Minix x7] [THe NiTro TeaM] [Alpha build]
Hello
After using your first quickshot rom since the beginning I recently tried some kk roms for neo x7, they are pretty near perfect beside the sound loss and intermittent black screen. Reading through many forums it seems that there are many others with same issue. Hopefully you may spare some time to get this rom closer to beta, so it maybe some glimmer of hope for the once legendary neo x7.
Sounds a bit cheesy I know lol...
Thanks for all you guys have done.
The Cyanogenmod development for RK3188 is pretty stuck. Currently there are 3 different approaches: 2 of them discontinued and the other one hasn't been updated in a while:
1. CM11 for Radx Rock by Jungle
2. CM11 for Freakbox by abdul_pt
3. CM11 for Minix X7 by Nitro Team
So I think it would be best if we combine our powers and work together on a functioning version of CM11 or CM12.
Check posts 2 and 3 of this thread.
I packed with the kernel from version1, so the USB2PC connection problem is still present. Other than that all other problems have been fixed. If you want to work around the USB problem issue "echo 2 > /sys/bus/platform/drivers/usb20_otg/force_usb_mode" from terminal, or add a init.d script with this command.
Originally posted by ballicali View PostDo this ROM support EXFAT?
Originally posted by darky44 View PostIt's possible have a version of kernel & cm11 for flashing in twrp? Please
There are currently 2084 users online. 0 members and 2084 guests.
