I bought a mk808b plus. Can't seem to find a solution on google. While searching i stumbled upon this forum. I get an error timed out when trying to browse with the stick. I have a 30 Mbit down connection and i use it via wifi. I have a second access point for better coverage around the house. I get the same message while connected to both points and showbox and other xbmc addons seem to take a long time to start streaming or do not work at all. Already updated the stick to the latest firmware.(not finless) just the stock firmware but can't seem to figure out what's wrong. It's suppose to work without an external antenna. I rebooted my modem. Change SSID. reset the stick. Same still error when using app. Everything takes a long time to load and i have several other tables and phones on the same network with no problems at all.
mk808b plus err timed out & wifi issues
Hello to all,
I bought a mk808b plus. Can't seem to find a solution on google. While searching i stumbled upon this forum. I get an error timed out when trying to browse with the stick. I have a 30 Mbit down connection and i use it via wifi. I have a second access point for better coverage around the house. I get the same message while connected to both points and showbox and other xbmc addons seem to take a long time to start streaming or do not work at all. Already updated the stick to the latest firmware.(not finless) just the stock firmware but can't seem to figure out what's wrong. It's suppose to work without an external antenna. I rebooted my modem. Change SSID. reset the stick. Same still error when using app. Everything takes a long time to load and i have several other tables and phones on the same network with no problems at all. -
Originally posted by Mindovermatterz View PostHello to all,
I bought a mk808b plus. Can't seem to find a solution on google. While searching i stumbled upon this forum. I get an error timed out when trying to browse with the stick. I have a 30 Mbit down connection and i use it via wifi. I have a second access point for better coverage around the house. I get the same message while connected to both points and showbox and other xbmc addons seem to take a long time to start streaming or do not work at all. Already updated the stick to the latest firmware.(not finless) just the stock firmware but can't seem to figure out what's wrong. It's suppose to work without an external antenna. I rebooted my modem. Change SSID. reset the stick. Same still error when using app. Everything takes a long time to load and i have several other tables and phones on the same network with no problems at all.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by Mindovermatterz View PostI already hooked it up to my monitor instead of tv with a different usb cable. What does a power supply have to do with wifi speed?Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 1323 users online. 1 members and 1322 guests.
