[PIPO-PROJEC] CyanogenMod 11 PiPo U8
    Hi guy's
    Thank's to Riley i got a PiPo U8 and started to play with it. So here's my port of CyanogenMod 11 for the U8.
    Don't ask if this rom is better than any other, because i really don't know any other. I only got the tablet last week, and didn't test it much.
    If you find a bug, please, post as must info as you can so that i can reproduce it and try to address it. Like the title say's this is a Work In Progress, and expect to find some bugs although it's stable enough for my daily use so i decided to share it.
    NOT WORKING
    Both cameras
    Here's some features of this build
    - TWRP 2.8.4.0 with a new theme of 768x1024
    - Unified Storage (Data and SDcard share the same partition)
    - Rooted with Koush SuperUser
    - CM file manager(root)
    - DSP Manager (CM equalizer)
    - init.d
    - busybox
    - Tons of customization definitions
    - Minimal Gapps installed
    How to flash
    - Download the file and extract it to your PC
    - Open RK Batch Tool or AndroidTool, select the FW image and put the U8 in bootloader mode.
    - Press Upgrade button.
    On first boot, stock recovery will format all partitions and reboot the tablet. Be patience and let it do his thing.
    After setting your account on the Setup Wizard, some of the pre-installed apps/services will have to be updated. I decided to proceed this way because i hope that future releases will not require the use of the PC and no data loss, like OTA.
    Enjoy and leave feedback
    www.freak-tab.de/abdul_pt/pipo/CM11_U8.tar.gz
    GPL Compliance
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
    ------------ NEW RELEASES -------------
    Check the end of the post for the latest recovery images
    Installation
    • Install the latest recovery available
    • Copy the downloaded zip to your SDcard
    • Reboot to recovery and choose to install the zip
    • Wipe cache and Dalvik
    • Reboot and enjoy
    NOTES
    * This is if you already have flashed the CM image in OP.
    * All of your data will be preserve
    Downloads
    -> 23/08/2015
    * Added some binaries to try to fixed reported Bluetooth problems, for some users.
    * Compiled TWRP alongside CM
    * Updated from upstream
    -> 08/06/2014
    * Both cameras working, video recording working, panorama working and flash working. Setting scene mode night will freeze the cam.
    * Added an apk to manage HDMI out. Thanks to jucaroba.
    * Other small fixes
    -> 05/06/2014
    * Added volume buttons to navigation bar. Remove "
    ro.rk.systembar.voiceicon=true" entry on build.prop to remove them
    * Added some missing libs
    -> 28/05/2015
    * Update upstream
    * Removed main hack
    * Set ADB shell as root, default.
    * Other small things
    -------------------- RECOVERYS --------------------
    [NEW] TWRP 2.8.7.0 - www.freak-tab.de/abdul_pt/pipo/TWRP_2.8.7.0_PiPo_U8.img
    CWM 6.0.5.1 - www.freak-tab.de/abdul_pt/pip....1_PiPo_U8.img
    parameter file - www.freak-tab.de/abdul_pt/pipo/parameter
    INSTALLATION
    • Download the recovery of your liking and the parameter file
    • Place the U8 in bootloader mode
    • Open RK flash tool to flash single image and select only the parameter and recovery file
    • DO NOT ERASE IDB
    • Press run/start
    • Enjoy
      thanks for you work!!!
      abdul_pt! big thanks, this nice rom, i install it. i dont see volume soft buttons on nav bar, you add volume button on next build?
      thanks, and sorry for my english.
        NP.
        Yes, volume buttons is on the to do list.
        I think there's and app that places volume buttons on the nav bar. I don't recall it's name.
        Hope that you enjoy it.
        Tapatalked
          i test this rom 2 days, and all work same rileyrom2.0, maybe even a little faster.
          lost blinking red frames in google chrome(its real good!!)
          wi-fi,battery, gaming, mx player(h/w, s/w rendering)local files and web, music, all work fine!
          not random reboot or force close app.
          for volume button i use xposed+gravitybox(nav bar settings) its add button on nav bar for open volume slider.
          thanks for great rom, and sorry for my english(again)
          and one noob question: after complite this rom, you create cm12 for pipo u8?)
            I have to deal first with two things so that I can try to move forward.
            I have to compile a working kernel and the cameras problem.
            Then we will see.
            And thank you for the feedback.
            Tapatalked
              Do you know that you can put a tile in quick settings that will open the volume slider ?
              Xposed on custom rom's may cause side effects.
                i know, but xposed need for screenfilter module
                  Thanks I waiting the new rom to fix camera & volume button.
                  Στάλθηκε από το HM NOTE 1W μου χρησιμοποιώντας Tapatalk
                    Thanks for the feedback.
                    Working on kernel, spent a few hours on it today.
                    This is a tough one. It boots but i don't get any image just backlight.
                    Tapatalked
                      hi! any news?
                        There are always news, but unfortunately not related to this topic.
                        But it's not forgotten/abandoned.
                        Tapatalked
                          Check second post for a small update
                            Abdul, how's that U8 working for you?
                            Randy
                              Abdul,
                              The open source repo has got all the code up to date and has a U8 def config and board file. Could you sync/add your current changes into this and then we could work together to solve?
                              The code as it stands builds to make this (1.03.01) kernel currently.
                              [edit]Any changes you need to make outside of the board file please wrap with conditional tags (#if defined (CONFIG_PIPO_U8)) and push back
                              Donate to Finless
