RK android tool and AndroidToolRelease, the last one can flash both type of images. In this folder a have some tools and driver's, i think they are up to date.
[PIPO-PROJEC] CyanogenMod 11 PiPo U8
After flashing CM 11 I got locked screen and my password doesn't work. Great!
write manual step by step, please. Not everyone knows how to enter in recovery and etc
Something wrong with this firmware. I delete LOSR.DIR from SD and flash Pipo_U8_RileyROM_2.0.1 again. Than I flash only TWRP_2.8.7.0_PiPo_U8.img and parameter.txt
It show a lot of errors:
Than I installed Cyanogenmod. And now I see only boot animation.
I feel sorry for the time spent. It's not worth it. People, use RileyROM.
I was asked to update the repos so here's a new CM build. This zip's are to be installed ONLY after flashing the image file in OP.
It's just an updated build, with all commits from CM tree to the date of 13/04/2016.
--> CM 11 20160413 U8
I have also build a new TWRP version. This is TWRP3 for the U8
--> TWRP 3.0.2 U8
Abdul Thanks for new TWRPi compiled it myself from your source and it works great
BTW ppl who wants flash your rom can have some problem especially newbe. I suggest to upload like RKAndroidTool + parameter , boot, misc, kernel and recovery.
And need to just select parameter, boot, misc, kernel, recovery in RKAndroidTool than EraseIDB, and Run.
Than in TWRP, format data, than factory reset and advanced wipe: system, dalvik cache. And after this just flash/install your CM 11 20160413 U8 and gapps and Reboot
Hello everybody! Freak-tab.de is dead. Please share http://www.freak-tab.de/abdul_pt/pipo/CM11_U8.tar.gz this file, sendspace.com is good service. Or any latest version of this firmware. Thanks!
There are currently 984 users online. 0 members and 984 guests.
