DigiLand 10.1 DL1010Q MT8127
    Originally posted by vampirefo View Post
    the above link is broken.. can you plz repost link.
    thanks
      hello, most likely this is unrelated.
      i flashed stock image on this tab and now the touch screen is completely inverted. does anyone have an idea how to fix this?
        i have the same issues.....can someone help me fix my Digiland Tablet ?
        Originally posted by djregehr View Post
        HELP!!!
        I have a Digiland DL1010Q. I had rooted it using KingRoot. It recently had a wireless update, NOT system update. I did the update and when it rebooted into recovery mode it got stuck. I can see Android system recovery screen with the options for
        1. reboot system
        2. update from ADB
        3. update from sdcard
        4. apply update from cache
        5. wipe data/factory reset
        6. wipe cache partition
        7. backup user data
        8. restore user data
        I have attempted every method. I can see info and recovery folder on drive and get a NO Command error when applying it. I've wiped cache/data/factory reset to no avail and still can see data on the tablet. It is obviously bricked, but soft bricked I believe. How can I push or get a stock or modified ROM back on this tablet so it will boot?
