I'm in need of some serious help from some people who know what they're doing..
I have two DL1010Q tablets. I broke one by my own fault, the other is fine. I've been scouring and reading and testing and I cannot fix whatever I broke. I deleted all the .ODEX files from the stock rom and now I cannot boot. After reading some posts elsewhere, it seems like this is what broke my tablet, but i'm not 100%.
Using MTK Tools I have backed up my working device, I have boot.img, recovery.img, etc
I have tried flashing the system.img using fastboot but I think the bootloader is locked so it never does anything, just sits at the prompt, never shows any progress or anything. Have tried at least 5 times with the same result. MTK Tools does not support the MT8127 so I cannot pull a scatter file, however, from the rom dump there is a firmware.info that looks almost exactly like what the scatter file should look like, but SPFT doesn't like it, so it's missing some formatting or something.. I have no idea.
I attempted to use MTK Tools to make a custom recovery but it errors out. Again, probably because the MT8127 is not supported.
My next attempt was creating a signed .zip that would replace the .ODEX files using adb sideload through stock recovery... this loads and starts to run and the gives "Installation Failed" and quits.
I saw you're wishlist and was hoping that someone here would take on the challenge because this is beyond my skill set..
I have a working, rooted tablet as well as a full dump using MTK Tools and am happy to provide anything needed from these files, or if you need something else, let me know and I'll try and get it!
All the files are in my Google Drive
