Rockchip Create Upgrade Disk Tool v1.4 helps you to install firmware on Rockchip device from Micro SD card
RK3288 Devices
- Overview BOX (LINK !)
I tried this and it works, however it will not fix a damaged nand. Nice little tool! Hopefully there will be an update to create a boot sd. I tried several times but it wouldn't go for me.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Originally posted by budgetgeek View PostI tried this and it works, however it will not fix a damaged nand. Nice little tool! Hopefully there will be an update to create a boot sd. I tried several times but it wouldn't go for me.
Now put the micro SD card in your Rockchip RK3288 device and power on. Now you will be able to enter into recovery.
Download 'Unbrick RK3288 devices' archive from here or from here, decompress it and copy the two files update.zip and update1.zip to (another) micro SD card.
From recovery you have to use an USB keyboard or an air mouse and navigate to 'Recovery update from external storage' and first choose 'update.zip', then follow the procedure again and select update1.zip. Next press on 'Reboot system now', and your RK3288 will restart with firmware installed.
Now follow the regular procedure and flash back to your RK3288 stock firmware, everything should be back to normal now.
It's an RK3188 M9Pro by Pipo. I tried to create boot sd but it would stop when trying to extract the system.img on both 4.2 and 4.4. I'll have a shot at it again later, but in stock recovery the touch did not work, however, I did not try the OTG remote.Currently Inactive on Freaktab.com
Originally posted by Renixo View PostThe easiest way to solve this, without need of short circuit of the NAND pins, is to use Rockchip Create Upgrade Disk Tool v1.4 to make a bootable micro SD card with your device stock firmware. So download Rockchip Create Upgrade Disk Tool v1.4, download your device stock firmware, launch the application, in first step select an micro SD card as removable disk to be used, tick 'Upgrade firmware' and 'SD Boot', then Click 'Firmware' and a pop up window will open. Select firmware image .img file and press 'Create' button. Wait about 3-4 minute and you're done.
请培养慈悲心和谦逊
Best regards : Gayble
Originally posted by Gayble View PostDear Renixo can you make a vidoe of Rockchip Create Upgrade Disk Tool v1.4 helps you to install firmware on Rockchip device from Micro SD card so that is easy for me to follow Thank you very much. My devices (Beelink R89 Rk3288 Rooted)RK3288 Devices
It looks like a very handy tool. I think I will stick with the AndroidTool flashing method for now, though. I like having options of different parameter files and different recovery/boot images to flash in my ROM's.Randy
Originally posted by Renixo View PostHere it seems to me that it is explained very clearly and simply:
http://forum.gsmhosting.com/vbb/f906...ualok-1786042/
Question 1)When i start up Create Upgrade Disk Tool v1.4 and it have a extra column call (Fourth:Choose demo (option)) can you please kindly explain to me
Question 2)Do this method able to work on (Beelink R89 Rk3288 Rooted Tv Box)
Question 3)Do you have TWRP img or CWM img for (Beelink R89 Rk3288 Rooted) if yes please give it to me thank you.Compassion Humble
请培养慈悲心和谦逊
I found an updated version, 1.43, and it flashed the whole image but it hangs on the parameter flash first, re format the card and try again and it works but can't boot. I know the stick mk809iii works, and the card works, I flashed linux and booted it. I need the android image to work because it can set the appropriate resolution on my tv, and has the right wifi module.
Can anyone else try it?
Here is link: http://www.mediafire.com/download/9n...Tool._v1.43.7zCurrently Inactive on Freaktab.com
If I understand correctly the 1st part of the Renixo's guide is to allow entering to the recovery?
If I am able to enter the recovery do I need to perform only the 2nd part?
There are currently 2204 users online. 0 members and 2204 guests.
