Run as an administrator.
Rockchip Create Upgrade Disk Tool v1.4 helps you to install firmware on Rockchip device from Micro SD card
I think i finally killed my tester mk902ii it fails to boot. I can get into recovery but the first update fails halfway through. I am able to flash back to stock kk but when i upgrade to anything but wasser .2 i get no sound its driving me crazy lmao. But sound works in kk. Think ill keep playing.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostI think i finally killed my tester mk902ii it fails to boot. I can get into recovery but the first update fails halfway through. I am able to flash back to stock kk but when i upgrade to anything but wasser .2 i get no sound its driving me crazy lmao. But sound works in kk. Think ill keep playing.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
One time more like 100 lmao... Anyways back on stock 4.4 if i flash anything else no sound. I re flashed and bricked it to get nack to mask mode. It flashed both update and update1 but did not re boot into any firmware. Hooked back up to pc mask mode again. Ill try neo modes atv once he posts update.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
I'm trying to use this to change the firmware on my MXQ 4K (which came with 6.0.1). I flashed the rom to the SD card (a sandisk ultra 8gb) but the MXQ only boots normally and ignores the SD card. I tried another SD card (a 4GB one that came with my Nintendo 3DS) but at the end of the flash it fails without any explanation. I'm trying to flash the rom from this topic http://freaktab.com/forum/tv-player-...erceleron-v1-0
What i'm doing wrong?
Originally posted by gefattern View PostHi kurocygnus ,
are you sure it works with your SoC RK3229 Device , is it not only for RK3288 ???
I dont know , u must use Stockrom no CustomRom from Superceleron . I believe .
good luck
gefattern
Originally posted by kurocygnus View Post
The CustomRom from Superceleron was made for the 3229, I believe. Doesn't matter now, I bricked my MXQ-4K because I'm dumb. I used the RKBatchTool and pressed the wrong button (Restore) and now my box is in Maskrom mode...
Restore or Upgrade no difference , flash must work , if your Box is in MRM you can flash
it easily again with a new Rom , best StockRom first , then any you want , if compatible .
good luck , report
gefattern
Hi again ,
good luck , report
gefattern
I tried to flash it in MRM, but it gives me a Test Device Failed... I think that's because my usb cable (which I made...) is not writing anything... I'll try a new cable tomorrow.
Originally posted by Babb1 View Post
It is the same for me. The same on Windows 7. I have tried Windows 10 64 bit and Windows 7 32 bit as well.
My chip is RK3399
How can I use this tool?
This version worked for me on Win7 , like Renixo discribed , but my Box
did not "boot" with it into Recovery , first 2sec Blackscreen then "no Input"
on Tv , like always before , since it bricked , hope i can get it back to Life .
good luck / gefattern
There are currently 2192 users online. 0 members and 2192 guests.
