CS918 RK3188??????
    CS918 RK3188??????
    Hi fellow media box addicts!
    I've been online for the past 2 days searching for a new firmware for the Android media player that I purchased a month ago. I searched high and low with no match found.
    I was wondering if anyone can help me, I've tried 13 different firmwares with no luck.
    Here's a picture of what I have, as suggested in the forum, I took out the screw driver and opened her up.
    The PCB revision number is X6_V2 1, 2014_09_20. The wifi/BT chip is RTL8723BU and the LAN chip is RTL8201P.
    I've tried the following firmwares:
    - CS918 1.24 (BT, wifi and LAN doesn't work)
    - szy_rk3188_box_ap6210_131213_en (remote doesn't work)
    - cyxtech_cs918_8089_6622_box_140512_by_Frant (doesn't work, bootup loops)
    - cyxtech_rk31_cs918_8723_140509_8G2G (remote doesn't work)
    - Geekbuying T-R42_ B351V2.0_20131203 (doesn't work bootup loops)
    - RAM1GB_rk31_EKB311A_8723au_4.4_140430_8G2G(doesn't work bootup loops)
    - rk3188_4.4.2_q7s_gc2155_zhongxing_v006_20140619(do esn't work bootup loops)
    - EKB311B(CS918)_Android_4.4-07.10 (remote doesn't work)
    - update_Q7_8_4(remote doesn't work)
    - update_Q7_9_28(doesn't work bootup loops)
    - update_without_xbmc_7_30_(remote doesn't work)
    - CYX_CS918 V2_3 KK Wasser1-0-4(wasser bootup loops)
    - EKB311B(CS918)_no logo_ROOT_4.4.2_20150122 (remote doesn't work)
    Here are some pictures of the box.
    I hope someone can shed some light on this.
    I have the CS918 V7.0 20141208 which has BT & Wifi. I'm currently going thru a learning process to build a bootable SDHC card so I don't have to flash the NAND. However - I have not gotten the card to boot properly - its only a matter of time until I solve this. Have you tested DTS passthrough? I have a suggestion for you - dump the remote and get a wireless keyboard, I ordered the "Rii mini i8 Wireless Keyboard 2.4G with Touchpad"from ****: http://www.****.ca/itm/121561145906?_trksid=p2057872.m2749.l2649&ssPageNa me=STRK%3AMEBIDX%3AIT
      ganjaman2009
      If you have done this with the bootable sd card, pleas can you make a small tutorial how can i get a bootable sd card preferably with a Linux ?
      Thank you
        Yes I will post it but this is a hobby, right now I've lent the box out to someone who is thinking of buying one, so when I get it back, I'll continue working on it.
          The currently available Android communities for RK3188 Kit-kat source code is extremely out-dated. Some repos are about 2 yrs old. This means I'd have to expend a lot of development effort just to play catch up by adding device support, 1080p (EDID patch) and interface tweaks. I was wrong when I thought it was easy to download android code that works with 3188. I'd rather spend another $150 or so on a Tronsmart or Minix rather than waste my time on crap I paid $48 on ****. I'm throwing in the towel.
            Rk3288 isn't much better, plenty of bugs, do some research before you give them your money.
              did you try to reset the box
